** 2017 DAYTONA F3-S (SE) NEEDS MORE LOW-END "PUNCH" - BEST WAY FOR REAL RESULTS?? **
Have read all the forums and even the ECM remapping (Monster) indicates the gains are really more on other models/different gearing and mostly at high RPM's..... (I have no interest in high rpm mods, power is great there and I don't push to the existing rev limiter anyways.) ~ There has to be some solution that will actually increase "out of the hole" performance so that I can get the rear tire to break loose if I want to!
I keep coming back to wishing there was a different drive sprocket option (2 less "teeth")..... Have never been over 80 on the machine anyways, and not concerned with fuel economy, I don't get to drive it long distances anyways due to occupation..... Just like to zip etc. around town.
As at least one other 2017 Daytona-500 (SE) owner has indicated on this forum: Very seldom is it possible to get that rear tire to even chirp from startup. (2017 F3-S SE Daytona-500 edition) You almost have to come over a crown of the road and "unload the suspension on rear tire" to get the rear tire "loose." (regardless of traction/control settings) Even around a slight corner it is difficult to break traction like the ads/video on Can-Am's website shows. Very seldom do I have interest in spinning the tire & I don't beat on the machine. But even on that occasional hard acceleration from a stop... Usually the only thing I can get (leaning off seat just like a snowmobile) pulling out of a parking lot etc. is a little inside tire lift...... As for straight line acceleration, FORGET IT! She has plenty of go, but without a clutch, that sticky tire refused to let go whatsoever.
HONESTLY: LOVE THE HANDLING, but I'm a little disappointed having spent the $$ on a 2017 (held out for T/C disengage capabilities) AND then not experiencing the stock performance portrayed on the Can-Am website. (Their promo video.) I was dealer principal/owner of a powersports dealer (4 brands, multi-seasonal products/lines) for ~17 years, and honestly: The capabilities the OEM marketing departments showed their stock machines doing (in their promo videos) were "achievable." ~ Not in this case..... <one thumb down>
FWIW: I have even thought about going with the OEM Akrapovic exhaust, but doubt that will make a difference. I'm not trying to make more noise either. ~ Although if it made a difference, a little different sound would be fine.) I remember back to the older Suzuki GSXR-1100 days where you could clip a single wire, and that unrestricted 1'st gear. Can't help but wonder if something similar is "at play" here!
Open to any/all reasonable suggestions, thoughts & ideas, but don't want to waste $$!  (And yes, I want to keep it quasi-legal & not void warranty.) :banghead:
How about tire pressure? Slightly higher (or lower) maybe? I'm running factory spec. pressure, never tried changing that.
