2016 RTL side case - front latch will not latch. Anybody else? Any fixes?
Baird4444
Rt. side case latch, the catch on the front will not "latch" so just the rear latch is holding, but not well. I can
flip the rear latch closed with a screwdriver and release with the handle. The front latch rotates but
will not "catch" and stay latched. This is more than a cable adjustment, right? I'm guessing the front side
latch is discombobulated... Anybody else seen this and dealt with it?
Also... where is the sensor for the "rear case open" light? I don't see a micro switch...
Thanx for any input - Mike
Pictures would make it easier to understand what is happening. You should look to see if the side case has shifted, maybe one of the hinges is loose or moved, maybe the latch itself has loosened or worn out. It could be a number of things that can cause a misalignment.
The catch should grab the post and hold, BUT it does not "latch" to hold. The hinges are tight.
If everything else looks good and it still won't latch, I believe you are looking at replacing that latch and possibly the cable.
I'm thinking repair the latch, the cable still releases the rear latch. I guess it's time to take off the tupperware...
After an evening of googling, searching forums, and YouTube, I think I've got an answer...
The front "Latch" does not lock. It just wraps around and holds the post on the lid. I tested this on the other side and it proved that. Now I'm thinking that all I really need is a cable adjustment. I'm feeling Lucky about this!
It is commonly a mis-adjustment of the cable that connects the handle to the locking mechanism. It has a lock nut and threaded adjuster. You can reach underneath and adjust it without tupperware removal. I did it by laying on my back and reach up. However, it is easier by removing some of the tupperware, but that in and of itself is a PITA.
whoa! I broke one of those tabs last time I was in there, I'ma gonna give it a try, THANX !
All adjusted and good...
Last time I adjusted, I removed that rear cowl and then the latch handle mechanism to adjust.
The process of getting down and just reaching up didn't work for this 71 year old arthritic guy...
I found a post where you remove that rear cowl then loosen the 2 fasteners behind the struts on the bag lid and the 3 at the top of the rear fender, then let the rear fender drop, and BOB'S YOUR UNCLE!!
It's much easier for me and my way of thinking...
