2016 RT Ignition Switch
Centaur546
The last 2 times I rode my RT, today and 3 weeks ago (it's been crummy weather in eastern WA) when I turn off the ignition key, the engine shuts down, but the dash goes off then comes back on as if I had turned the key on. I cycle it thru on/off real quick and it comes back on with the key off and removed from the switch. I have to do this a couple of times until it finally shows the SPYDER logo and turns off. Is there a simple fix to this or do I need to replace the switch?
Probably not this, but will mention
If you somehow had the mode button pressed, that will shut down the motor and leave the the electrical system on, say to play the radio while you work on the bike. Does exactly what you see, flash off then back on. Have to turn key on until logo, then off again to stop this mode.
