Bob Denman
Doc,
I'm pretty sure that's what I was seeing under mine... :shocked:
The shims arrived. I tried just holding them in place and as luck would have it, it seems one is not enough and two are too many. Two of them are too thick, leaving the new plate resting totally on the shims. Just putting one shim in there left the new plate resting totally on the plastic tabs and the shim rattling around freely. Tried all four locations with the same result.
I measured the powder-coated shim thickness at 0.053" give or take. With one shim in there, I used feeler gauges to estimate the remaining gap at 0.036" or total gap with no shims of 0.089". I suspect gently torquing down on the nuts to pull the plate in a little would decrease that gap slightly. I measured the depth of your protrusion on the original backplate with milled ends and got a protrusion depth of about 0.075". If the protrusion length had fit in between my plastic tabs, as it did on yours, that depth would have worked out pretty close. Don't know if it would have fit perfectly but pretty close. I'm sure that's exactly the way you designed it and intended it to work. I think the bike-to-bike variability is back to haunt you. Short of supplying a range of shims with each kit to allow each hinge plate to be custom fit, I'm not sure how you can get this to work for all. Or just draw the plate up gently against the plastic tabs and leave the gap alone. I defer to the expert.
They arrived today! :2thumbs:
Yes!! :yes::yes::yes:
Sorry... we've been busy around the house this weekend, and I forgot to post about it...pps:
My shims weren't color coordinated, but it only took a set of dial calipers to figure out the sizes that I needed. :thumbup:
Doc, Please PM me your PayPal info... Even though I was a guinea pig for these; I want to pay you for them... THEY ARE THAT GOOD!! :2thumbs: :firstplace::firstplace::firstplace::firstplace::firstplace::firstplace:
PM me your info; I've got it covered! :thumbup:
I'm thankful for the chance to "Try, before I buy"!
And they're worth every penny!! nojoke
:shocked: You have one of them also?
(A Kathy...)
We are truly lucky men. :thumbup:
Please Thank her for me... I don't deserve this...
