2015 RT very hot
Bob S
I have a 2015 RT Limited.
I am noticing that after I go for a ride (30-40 minutes) and leave the Spyder in the garage, it gets really hot, especially around
the inside of the small compartment on top of the gas tank. The plastic ​area around the key hole is almost too hot to touch.
This lasts for hours.
The last modifications were the addition of the BaJaRon Sway Bar and Shock Adjuster. I don't see how that could make any difference to heat. I never really felt around the dash area by the key hole.
Is this normal?
Thanks,
Bob S.
Yes..When sitting still the heat will try to escape but has little air movement when in the garage.
The bar and shock adjuster will not cause this..Its normal
Agree..!!
once parked and especially in a closed garage all the engine heat rises straight up. This is normal on all spyders. If you out and get air flow it will cool down quickly...:thumbup:
I learned this the hard way when I put a bag of chocolate covered almonds in my glove box. :banghead:
Pam
When you pull into the garage, lift the seat up, it will allow for better ventilation under the bike and allow it to cool quicker. :thumbup::thumbup:
Cruzr Joe
I threw the whole bag into the freezer and ended up with a very large, odd shaped, nut filled chocolate bar :dg2:
Pam
:shocked: I gained two pounds just READING about it; :thumbup:
attachment.php
