2015 F3 BRP shield mount DIY mods no buffeting, good wind protection
spyderyderjim
Hi All,
My 2015 F3S BRP Blue Ridge shield mod raised up 6", moved rearward 8" with DIY Aluminum side mounts/brackets.
No head/helmet buffeting at 80 mph on Hwy 10 Arizona.
BRP F3 raised up shield deflects the wind over top of helmet with mod, no wind buffeting.
BRP F3 shield 16 1/2" height from top of center handlebar mount to top of shield, 24" from top of shield to front of eyeglasses; (about same closer shield position as an RT).
Another option for BRP F3 shield.
Bottom line: it works well after the DIY mount mods!!
Enjoy.
Jim
BRP shield right side view 30 percent IMG_4022.jpgBRP F3 shield looking thru view 30 percent size IMG_4023.jpgBRP F3 shield front view 30 percent size MG_4027.jpgBRP F3 Blue Ridge shield 30 percent size IMG_4016.jpg
so where did you get the new mounting components?
Hi,
I DIY built/cut/drilled holes from 13" long x 1" wide x 2" wide x 1/8" thick Aluminum angle; 1/4" thick x 1" wide x 10" long Aluminum flatbar for braces.
The 1 photo shows Aluminum mounts after cut/trimmed/holes drilled/braces bent at bottom to attach to cluster rail bolt.
Jim
Hi,
Jim
Ahh ok so you lost me at built/cut/drilled, that's to complicated for me, lol
Amazing Accomplishment
You continue to amaze me with your windshield mounting development work:clap::bowdown:
Jim
I see you've been playing again in the Spyder garage!
Hope you've been doing it early it get's Hot out there.
I was invited :(
Do your handle bars not hit in a full turn?
As you can see by this photo of F3 handlebars in full lock left
there is plenty of room for my handlebars to turn without hitting BRP shield.
It looks like BRP F3 engineers designed this shield to fit higher, with the shield cutouts to clear full lock handlebars.
F3 shield just needed to be mounted about 6" higher & 8" more rearward toward driver, (like on an RT Spyder shield position).
Jim
