2014 ST limited won't start
Beaudog
I have a 2014ST limited. Started it this AM backed it out of garage turned it off. Came back 5 or 10 minutes later it cranks but does not start. No warning lights and no codes on the fault code page.
Put on Battery charger. Brought to full charge still no start.
Any suggestions?
Any suggestions?
It sounds flooded.
Twist the throttle to wide open and hold it there.
Push the start button and crank the engine for 10 seconds.
Let the starter cool for 1 minute.
Repeat wide open throttle crank for 10 seconds and allow starter to cool.
Then do a normal start.
If it is really badly flooded you have to do this again.
Twisting the throttle wide open before cranking the engine turns the fuel injectors off.
o . k an old trick
I am not sure of this for the can-am -ers spyder , but on some of the older bikes , you get a vapor lock in the tank ... your in Arizona , was you cycle in the garage ? ---- try opening the gas cap --- if I am right you will hear air rush in , a vacuum from going to a cold spot too outside temps . try it any way if not in a cooler location at the time of the 1st start ... { when I roll out my 2 wheeler , and the temp is some what high in humidity , I can kind of roll the gas cap under my palm and you can hear the air rush in ) hope it is this easy --------> p.s. my :f_spider: rider buddy --- kill switch ?
Tried both of those and checked all the fuses that would have anything to do with starting (I think).
It was hot almost 100 I will let it set over night and see.
Double check the KILL switch
Some bikes won't respond at all when the kill switch is off and others will crank until you run the battery down. My '15 ST Limited is currently in the shop with transmission issues, but I think Spyders will crank as if nothing is wrong!
The fuel tank should be at or near atmospheric pressure. So if there is a vacuum. that needs to be fixed.
Spyders will not crank with the kill switch is in the stopped position. So that is not what is wrong in this case.
As I see it...
Generally one of two things...electrical or fuel related. As it cranks it is not the whole battery thing but still can be an ignition/spark/coil issue. And as for fuel could be in the fuel dilivery , injectors, filter, or the supply lines...:dontknow:
Hot No Start?
I assume (and we know what that does) that since you are in Tombstone it is HOT. I believe that there is a High Temp Limit in the Control software that is sensed from the AirTemp sensor that will shut the bike down if exceeded. We don't worry about it here on the coast but that could be an issue where you are. Soaking in the sun may have cased a problem, check the Air Temp displayed Value at the top of your display screen, if it is over 130F. or so that may be the cause.
Also the boiled fuel in the injectors flooding the engine would be the most likely culprit as others have said along with the correction measures.
Anytime there is a problem, others here have had it and someone has the fix. :yes: Not me , however!
Update?
Any luck ???:dontknow: The TWO (throttle wide open) usually fixes these the first go round:thumbup:
No luck had it in the garage all night and it was cool this morning so don't think it was heat. I don't have those special triangle shaped torex type sockets to get the panels off so guess I will just haul it to the dealer later in the week after the 4th.
Thanks for all the suggestions. You would think it would throw some type of error code but it does not.
TOOLS
Torx look like an - asterisk " * " ..... and you have them in your tool kit in the Spyder .......T -30 for almost everything ..... Mike :thumbup:
Are you talking about the Givi tool to remove the luggage mounts. If so you got one with your Spyder when new. Probably in the cardboard box of extra stuff from the GPS. This is what you are looking for.
If you really don't have one. You need it and can be order through your Spyder dealer, from Givi or some aftermarket vendors as well.
You need to have this tool and carry it with you at all times. But I am not sure why you would need it for a no start problem?
