spyderyderjim
Hi all,
Several RT owners have had problems NOT able to open Frunk or Seat lock with ignition key; or (key inside jacket pocket that is inside the Frunk).
1. I installed a Emergency Frunk tether, (#14 primary wire with plastic coating; color coded to match glove box, if you like).
Ran wire from Frunk release to behind left side small panel; just pop left panel off & pull tether to open Frunk!!
2. Also ran wire from seat release through a sheath behind upper right panel up to glove box as an Emergency tether to open seat latch to be able to fill gas tank.
Update: run emergency seat release wire behind right side upper panel. Much cleaner look.
Hope this helps Spyder ryders out of a jam!
Enjoy the ryde!!
Jim :yes:
