ricford
A forum member told me the filter was on the left side (I'd opened the right and found nothing of interest) and armed with that small bit of info, I dug in. It was easy-peasy. Remove the upper tupperware, the sound baffle and the cover of the air cleaner is exposed. It has but three torx screws and two are easily reached but the third is just an angled torx device. I got a set at Sears for about $14 that was extremely useful. The red is the original filter.
Note that the K&N has a head piece that has a flat space that mates with the protrusion built into the air box cover. There is an up arrow on the cover. Just align the new filter to that protrusion and it will hold the filter in place. Just push it in, give it a twist to make sure you've inserted properly, re-align and button it all back up. Should take 5 minutes to replace the filter on and off and whatever time you take to remove and replace the tupperware is total job time. Less than an hour for me.
The filter is K&N part number CM-1314. To use K&N is of course a personal choice. I've had NO issues with K&N in two BMW K1200LT's, BMW 528i, Avalon and Chevy Silverado. In the 4 wheels I also always change the mufflers to FlowMaster. I have always found it allows more air and never had an issue as one member has reported with 'stuff' coming off the filter. Imagine that hundreds of NASCAR engines use K&N so....
