Hi Pete and thanks for reply.
If that thrumming is rhythmic (not constant) then that's what I've got.... ....
That it is! :thumbup:
Sorta sounds like some of the sprocket/belt teeth match up a bit better & make little or no noise, while others don't, so they make noise.... :dontknow: Only the 'frequency of thrumm' isn't anywhere near fast enough for it to be happening on every rotation of either the sprockets or the belt - so I reckon it's gotta be something to do with the harmonics of the belt teeth, sorta like the deeper resonance you get behind the plucked notes when you're trying to tune a guitar & the strings' tune doesn't quite match, if that makes any sense to you?!
That 'three pea-sized spots of grease spaced evenly around the sprocket' test usually quietens the thrumm for a little while, except for on that one Spyder with the 'machine gun' noise I mentioned, a noise that was due to the belt teeth skipping over the teeth on the sprocket under aggressive acceleration - the grease test only made that noise worse, but at least it made it pretty clear what was going on! :shocked:
I'd guess that if you've still got the noise after replacing the front sprocket and the belt, then maybe it's the teeth on the rear sprocket that are the issue (just call me Captain Obvious if you want!
Good Luck! :cheers:
Ps: I reckon it's a good call going for the Silver/Pewter 'Sprocket & washer' with the newer HT bolt over the older ceramic coated White sprocket - if you're gonna replace it, then you might as well get the latest and greatest 'fix' even if you haven't seen the problem yet!
I haven't been able to inspect them side by side yet, but I suspect that the Silver/Pewter or whatever colour on the latest 'sprocket with washer' is a similar ceramic coating to that they put on the White sprockets - a coating that was applied to reduce the obtrusive 'wind noise' the sprockets made on the newer models with less tupperware covering that area; so by fitting that one you'll be killing two birds with one sto.... errrm, sprocket! :thumbup:
