2013 RT limited stock floorboard/ break pedal
Tny434
Okay..can I adjust my floorboard where the break is..the front of the floor board is a little to low, but it is clicked in place for the giveaway.. Or could I lower the break pedal.any suggestions on how to do this.
I'd caution against any attempt to lower the brake pedal, in relationship to the floorboard... :shocked: It's a carefully co-ordinated dance that you've got going there! :shocked: The floorobard is designed to drop away; should the pedal be mashed in an emergency situation. :yikes:
If you lower the pedal; you'll probably be hitting that breakaway point far too early in your braking...
Thanks i figured i have no choice but to leave the giveaway alone..thanks
