2013 RT BODY PANELS
Tatonka
Anyone found it necessary to replace the body panels? I installed a short antenna and thanks to a YouTube video from Lamonster and Pierre at spider accessories.com I figured out how to takeoff body panels and remove the old Loctite'd antenna. But when putting it all back together, I broke some connections on the rear body panel. So I was wondering where replacements could be found......
parts
Also check here http://www.2wheelpros.com/ I have used them many times in past and found that they are ussualy cheaper than Cheap cycle parts.
yes, not one but both of the lower tabs....I will ck those sites..thanks…..I was thinking that if I could get replacement panels maybe get a different color than the bike..as the bike is red...maybe black rear panel would look good?
They actually stay in place quite well with both of them broken. When I he put the LED flag on my bike Spyderlyter found both of the broken on my Spyder. Since I bought my Spyder used I have no idea how or when they were broken. We just bolted it back together and it is solid so far. So you don't actually need to replace it if you decide not to.
Right, I think it's secure enough. I was thinking about putting on a panel of a different color. Found some at the recommended websites $200 plus I also found some on eBay new and used … So I think I'll just keep checking Until I find a good deal. May look for side panels as well just to give it a different look.
I had a cracked tab on main left side body panel of my rts 2017. The orig material was very thin and probably got installed without a washer. whoops. This twisted the tab. I did a couple of little checks with abs material and the abs glue that seemed to stick just fine to orig body panel. So I made up a new tab and glued it in place, no one would ever know. Rode this past yr, loos like I had just fixed it. This method might work on most of the tabs if they get damaged, maybe even reinforce damaged holes.
My 2 cents
If you saved the tabs, buy a kit of “The Last Glue”. I have fixed lots of them, and it seems to work the best. Online.
I broke one of those tabs also. Read on a post in here to glue back on with PVC pipe glue. Worked great, have even had it off a couple times since with no issues, now that I know how to take it off and put back on without breaking it.
