2013 RS-S to ST-S Handlebar switch
HuckFin
I want to switch my RS-S handlebar to the ST-S handlebar. I have talked to BRP and local dealer, they both say they should bolt right on, but they don't know if the plastic center steering cover. (fits in front and below center handlebar and covers ignition switch) will bolt to the bottom of the ST-S handlebar....So I'm hopeing I am not the first to try this and if there is someone out there that knows. Also RT handlebar should bolt on too...I am talking 2013 here, earlier bars are different....Oh, one more thing....Could the ST-S plastic center cover work instead?
If you look at the parts diagrams from Can Am, they all use the same part number on the steering column. It does appear that handlebars are now compatible across the whole 2013 model line up.
I know, I have already looked it up....but I need to know if the plastic steering central cover will fit...Looks like I will have to go ahead and order it and hope it works.
Is all of your wiring long enough to make this possible?
I can't say for sure, but from what I read about installing after market risers I would say so....I just got done ordering the 2013 ST-S handlebar center section along with all the plastic covers and hardware so I'll be finding out.
How about ST handlebars on a 2009 GS-SM5, is it possible?
Its possible, the 2008-2012 handlebar, bolt on... Near as I can tell with a 4 bolt adapter plate bolted to the upper steering column. Looks like if you took the adapter off, you may be able to bolt the 2013 handlebar center piece directly to the upper steering column,(same way the 2013s are) providing the bolt pattern is the same. I will be taking my 2013 handlebar off, hopefully this next week and can measure the bolt pattern.
Also, I might add if the bolt pattern is not the same, someone will probably make a adapter/riser plate, I'm guessing in the not to distant future.
Oooooooooo YEAH!!! This is what I'd be interested in :2thumbs:
So if all the 2013s are the same, how come you can't use the adjustable bars from the 2013 RT on an ST?
I haven't seen any reference to the RT adjustable bar in my 2013 service or parts manual...also, I won't know for sure if I can install the 2013 ST-S on my 2013 RS-S untill it finally gets here....Hopefully this week.
It fits!
I just got the 2013 ST-S handlebar and bolted it in place of the 2013 RS-S handlebar.....Perfect fit. The RS-S plastic center piece (fits around the ignition switch) bolted to the ST-S handlebar, so no problem there. If anybody orders one of these, make sure you get the R/H and L/H steering covers for the ST-S bar also the manual says to use new bolts....When I figure out how to, I'll post a picture.
:2thumbs: Glad to hear that it went together without a hitch for you! :2thumbs: :yes::ohyea:
But if you REALLY want to go tall... Ape Hangers02.jpg :D
Looks like I got ahead of myself. I am going to have to trim the left and right hand plastic bottom covers and the wiring on the left side handlebar might be too tight, so I'm going to take off the r/h body panel and see where the wiring goes....Hopefully this afternoon.
Ok, got the plastic bottom covers trimmed back a little and got some slack in the wiring.....Looks good!.....Now I will have to get used to sitting in a more upright position, but my wife is going to love it. ;) So now I guess I need to get a higher windshield and probably a Corbon seat...Floorboards?......
