2013 front tire pressures
Spydr in KS
What are you guys finding as a good pressure for the new low profile front tires? I had 13 psi on my ST from the dealer and it handled fine, pumped them up to 18 psi and I hated it.:( It rode rough and bouncy and didn't track as well.
So I am now running 16 psi and it handles smooth, solid and like it is on rails. :yes:
So I think the best pressure will be very different from my 2008 GS
Glad to hear that you've found a "psi" that's working for you...
It wouldn't surprise me tht the 15" tires will work well with less air in them. They've got less sidewall to flex around! :thumbup:
"Old"? :shocked:
How about "Seasoned"? :D :thumbup:
There's no doubt that the changes to the 2013s will require some different tactics for the old topics...
"Adapt and overcome"! ;)
My 2013 is still in the garage waiting for spring. I appreciate you folks down south chiming in on the new models. My ball joints are on order and higher temps are right around the corner! Keep the info coming! :popcorn:
I got to sneak out today for the Maiden Voyage for 2013... :2thumbs: Let The Good Times Roll!! :yes::ohyea::yes::ohyea::yes::ohyea::yes:
How about back tire pressure?
Spyder in KS, What are you running in back tire pressure? I have a ST as well and wondered.
Thanks!
So what pressures did you use front & back on your '08 GS, which is what I have?
Hiya Goat!
The general concensus seems to be somewhere around 18psi up front, and about 26psi in the rear...
But you've got to season it to your own taste! ;)
We had somebody in here get phenomenal mileage out of his rear tire... I don't remember what pressures he was using... but you might want to try and find his thread about it...
Hiya Goat!
Thanks luv that goat :thumbup:
If I could find the right way to download it, I'd grab of copy of it for you...
The website that I hooked up with for it has since shut down... :shocked:
