Sarge707
In the 2013 RT manual p.153 it says you can make the rear 12V power outlet run all the time by changing the fuse from the 6 slot to 7 slot in the right fuse box.
"When fuse 6 is installed, 12 V power outlet is only operational when ignition switch is at ON position. When fuse 7 is installed, 12V power outlet is always operational."
I did this and it works.
:clap: You Made a Lot of New Owners Happy!!!!!!!!!!!
