2012 Spyder RS won't run, dash doesn't light up - any ideas?
Chasdog
I just bought a 2012 Can am Spyder RS. I got it knowing it wouldn’t run. I did some work on it today. Fuses were all good in the front. Lights come on the bike but the instrument panel doesn’t light up. I’m thinking I’ll have to take it to the dealer for diagnostic review but was just wondering if anyone has an idea to try before I take it to the dealer. Turning the key to start it makes a little moaning sound but engine doesn’t turn over. Any thoughts?
First thing to check is the battery! :lecturef_smilie:
What you describe above are classic indications of a dead or dying battery on these power-hungry machines!! :sour:
If your battery doesn't show more than 12 volts on a multi-meter at any time while trying to start the engine, then it's probably not up to the task, and one of the early indications of this is that the dash won't light up.... :rolleyes: If you can give it a good 8-12 hour charge on a proper battery charger/maintainer (& NOT just on a tender - there's usually not a high enough charge rate from them to be sure!) it might come good for a while; but if your Spyder battery is ever that low that it can't hold 12 volts during starting, then it's pretty much time for a replacement, if not immediately (cos the charge thing didn't help... :p ) then soon, regardless of if the charge thing works for now! :banghead:
Good idea to fully charge the battery before the install.
Not a trickle charger
But an "intelligent" charger that drops to maintenance mode when fully charged.
Thanks Peter. I bought a new battery that I will try tomorrow from Napa. I’m hoping it’s that simple.
It may be 'new', but unless you know for sure that it's already been done, it's still worthwhile to properly charge that 'new' battery for 8-12 hours on a smart charger BEFORE installing it - they usually only come with a light charge, and if you want them to last as long as possible, it'll need a full charge before its first use! :thumbup:
Good Luck! :cheers:
Well the old battery failed to fully charge. Installed a new one and it started. Thanks guys for the posts. I thought it was more than a battery problem after listening to the previous owner. So I was excited to see it run. According to Napa it was fully charged but I think that is good advice to further charge it.
OLD BATTERY or Dead or low charge battery, loose cables
:congrats::thumbup: good luck with the rest. Now can edit/add signature & garage info:popcorn:
Loose cables has bitten me a few times when I had my Honda Shadow. I would tighten up the bolts when I installed the battery, but no matter what, it wouldn't start so I had to recheck the tightness, and sure enough, they were loose even after I initially tighted them. It was the strangest thing. Never failed though. Had to do that every year because at that time, I did not have a battery tender so I removed it in the fall.
A nearly dead battery can readily show full charge. It's just that a full charge on a near dead battery represents only a small portion of the stored energy of a good battery.
STAR..... washers are your friend.... I've been recommending them since 2012 +/- ..... Mike :thumbup:
So the battery issue is solved but the display doesn’t work. I took it for a very short ride and none of the gauges work. No mileage shown and the Speedo and tach don’t work either. The shifter also will not shift and it’s stuck in gear.
I have checked all the fuses in both locations and all appears well. I have made an appointment at the dealer to have it diagnosed but not until mid May. I had most of the panels off and didn’t see any broken wires etc. So I’m open to suggestions.
Have you checked the plugs and wiring going into the back of the dash module?? :dontknow:
A few here have reported issues with the plugs either vibrating loose over time, or there being a few pins in the plug/connector that were either bent or recessed so that they only made contact when everything was exactly correct & firmly plugged in. :shocked: Most have resolved those issues simply by un-screwing the dash retaining screws; leaning the top of the dash module toward the rider/rear of the bike; then unplugging the dash/loom connectors; inspecting them carefully; rectifying any bent/misaligned pins; and securely re-plugging the connector/s into the back of the dash module. ;) It sounds like at least having a look may be in order?! :thumbup:
Good Luck! :cheers:
I just bought a 2012 Can am Spyder RS. I got it knowing it wouldn’t run. ..... Any thoughts?
Did you get a chance to ask anyone why they thought it wouldn't run?
Big difference say between I parked it and now it wont go........
and it was running fine ,and then it just quit for instance.
Edit.
I just reviewed the thread and found you wrote in post #6
What did he say?
Helps heaps if you give all available info when asking questions from the onset.
In the meantime I would ensure that battery is maintained on a charger as I guess you have been cranking it some. And check the plugs on the rear of the dash as it may have be detached somewhat.
Here is some info on dash removal that may help
https://www.youtube.com/watch?v=YMGVQ1UY534
https://www.youtube.com/watch?v=WlzLAFT_EcA
couple months ago , I took my Spyder on a 40 or 50 mile ride started fine that morning , stopped a couple times for a drink or bathroom stop. then I stopped at a Music store for some strings, walked out....... turned over just a little and dash went black ... I am a retired Mechanic so my thought was dead cell in the Battery . anyway, I called AAA they came pick me and Spyder up took us home , I bought a new $150 battery , that wasn't it... it was the Battery Ground Cable where it was bolted to the Frame under the seat , about 12" from the Ground post on the Battery ... might be a good thing to check. . . just a thought
The previous owner had said that one day it just wouldn’t start. He was not very mechanically inclined. He said it was a 3 cylinder engine when it is in fact a v- twin. So there was not much help in what the problem may be.
The previous owner had said that He was not very mechanically inclined. He said it was a 3 cylinder engine when it is in fact a v- twin. So there was not much help in what the problem may be.
Himm.. OK
So what made you think it was more than a battery problem
after listening to the previous owner, when he said one day it just wouldn’t start? :dontknow: Cant figure that at all.
Must have said more than your letting on for you to think it was more than a simple tired old battery.
Did you manage to check the connector on the rear of the dash?
I tried pulling the front screen off yesterday. According to the manual there are a couple spots to insert a screwdriver and pry it off on the top of screen. The way the top where the safety card resides hangs over the screen and nowhere to insert a screwdriver.
I pried it from the side and was afraid I would break the plastic, so I backed off.
The reason I figured it was more than a battery problem was the previous owner had been looking for someone to take it to the dealer to get it fixed for about 2 years.
My screen surround didn't want to detach along the bottom.
Lamonster just pulls on it in a video with his fingers.....Pops right off. Smartypants. :D
Turned out some steel clips were sticking along the bottom on my F3.
Sorry no photo.
I pry with some plastic levers.
I inserted 2 of the L shaped ones between the screen and the surround.
Left them under a little tension while I decided how to proceed.
It popped off while I was deciding what next. :yes:
I removed, cleaned and lubed those steel clips and the plastic ones before reinstalling.
