Hello:
Today while out riding our 2012 Spyder RTS-SE5--my wife said she felt like she was sitting lower to the ground then normal and noticed that it was easier to get on the bike then normal. I noticed too my headlights were hitting signs in low beams.
So I went to adjust my airbag in the rear suspension and all of a sudden on the Dashboard control it says in ORANGE letters where the air pressure guage for it used to show what level of hardness it was setting the word MANUAL and I can't seem to adjust it.
So, what does this mean? Does it mean my pump has gone bad?????
I just had the bike in for service where they connected up the rear heated handgrips that were never connected apparently when the bike was new.
I had complained to the mechanic that the air pump for the rear air bag seemed to run too much. He told me they updated the BUDS system and it should not run as frequently or as long as it had been. So could this now be a actual problem?
and If I do air it up manually---what pressure should I have it set at for medium to high. It seems like the air has some how bled itself off. It was set to medium high before this occurred.
Could it be a blown fuse? Are all fuses located up front? In the FRUNK?
Any help and suggestions would be appreciated.
Thank you!
Thank you!
