2012 RTS Overheating Issue
LouW
Hi, Just looking for a few opinions on this. I was riding today, one of the first times this year. I was stopped in traffic and my temp gauge suddenly shot up to an overheating reading. The computer went into limp mode. Pulled out in traffic and the warning went away. The bike cooled down and limp mode disappeared. It happened twice. But in between the two incidents I was stopped and everything was fine. I checked the coolant level when I got home. It so damned hard to see in there but it was fine. 2012 RTS so its the 900. What do you think?
If the temp reading on the Spyder it will throw a code. I do not know at what temp. Does your fan kick on when at a stop? Radiator plugged up with debri? Water pump could be bad. Bruce
Fan is working and the radiator clean.
I read #2 & #3, the 2012 RT could run HOT, however it wasn't an issue unless something else was bad .... the 2013 Spyders had over-heating issues because BRP had to put the V-twin into the NEW 1330 frame .... BRP designed a cure that involved TWO inlet scoops wher the upper grills are located..... IMHO your radiator fluid should still be able to cope with the heat ... My 14 RT has the orig. fluid from when I purchased it ..... it is possible the water pump is not working ..... keep us informed .... Mike :thumbup:
When was last flush?
FYI maybe-maybe not responsible for killing pump impeller :dontknow: . Did easily go a year over the two year recommendation. Did hold out for 70k miles can easily DIY the thermostat
Suggest change the hose clamps to worm gear type (for future maintenance) While it’s off should be able to push on diaphragm to test if its stuck. Also suggest draining from bottom hose & not the froglets drain plus on radiator. Too many reported breaking, be careful to not mix antifreeze colors :lecturef_smilie:
