2012 RT-S: My modifications
spacetiger
I spent 6 hours today putting in last 3 mods to add to the 4 previous changes. I thought it was time to post the all changes and my impression on the change:
1. OEM Comfort seat: I'm only 5' 11" but the stock seat is too short, so the switch allows me to sit back almost 2". Padding is okay, cost is high (~$580), and it matches the backrest. The added comfort with increased leg reach (I have a 31" inseam) makes this a must do in my opinion. Passenger room is still adequate. Verdict: I would recommend this change if you tour.
2. OEM mirror in the back top case: Got it on sale (but still $57 delivered) because I needed a mirror to make sure the hair isn't too goofy at work. Mirror stows up zippered and has a small storage area above the mirror. The mirror is wide but narrow. I kept a small brush in the storage area only to have it fall out of the pouched area and land on the mirror. 4 hours of riding marred the mirror almost beyond use. I will have to buff the marks out. Verdict: there are better lower cost options.
3. OEM soft luggage: I got the side and front soft bags (front $89, side $52) for when I tour knowing they were sized for each respective cavity. I bit pricey but they fit, well made and much less than the semi-rigid option. Verdict: Not a lot of packing, but they fill the cavity completely so worth the cost and recommended if you tour.
4. Aftermarket handlebar center bracket for GPS via ram ball mounts: Why these are so pricey is beyond me. Its a simple bracket with 2 square ramball mounts, one on top and one on bottom. I can mount 2 items (GPS - Nuvi 255, iphone, or cup holder... I have other mounts for cameras, electronic pass, etc.) ~$100 for the bracket, bolts and 2 ramball mounts. I have not routed the GPS power cord, but still have used this many, many, many times. Verdict: must have, especially if you tour. Put a bag over the GPS unit if it rains.
-------- I did these mods below today ----------------------
5. OEM vented 25" windscreen: Surprisingly, it is same height but a little more narrow. Took 30 min to swap the windscreens. On sale for $260 so not too bad for the vented windscreen; it would have nice to get a tinted windscreen. Verdict: I think this is a nice upgrade but not mandatory.
6. Aftermarket drive belt tensioner: $266 from smoothspyder. A bit of a pain in the ass to put it on, the instructions did not deal with bike parts you had to take off; only with instructions on the tensioner itself. It probably took me 3.5 hours because I was going slow to not damage anything. I took it out for a spin after installation - almost all vibration at speed is gone. Verdict: I took a 4 hour trip without it riding at ~75 mph right in the vibration band... it was a dark mark on the design. This mod eliminates the vibration making this a must do if you tour. If you only ride 2hrs at a stretch you might be able to tolerate the vibration.
7. Aftermarket swaybar: $239 from Bajaron. Very good instructions, took ~2 hrs to put on - again going slow. Verdict: get one, the bike handles so much better.
I have a few other things to do before I start logging the miles to see how the design as modified holds up. The most important one is switching out the brake pads to semi-metallic. The OEM pads are awful, you have to really jam the pedal to get close to lock up. Even so, the rate of deceleration almost makes the bike a safety hazard in my opinion as there is enough HP to get you going, but not equivalent stopping potential. I have several other bikes, even my Aprilia SportCity 250 with semi-metallic pads stops better (and has better feel) than the Spyder!
Jerry
[edit: added pics]
Busy busy..!!
are you getting any ryding in..?? Times a wasting..!! congrats on getting all that done...:2thumbs:
:congrats: I agree 100% with your assessment on the mirror! :thumbup:
:lecturef_smilie:Don't put anything up there with it!
A few more mods completed:
8. Nets for the side and top cases. They were less than $17 shipped. They are not big and the mounting hardware is a bit weak, but they are very good buy. For the side cases, they make use of that indent in the lid. I find I can pt my wet suit in the indents and leave the case space empty - see pic. I recommend them as an excellent value.
9. OEM Rear top cargo shelf. On sale for $47 including shipping. I thought this fit differently into the top case and was a strong mid-shelf concealing "stuff" under it. Sort of. It isn't very stout and relies on a strap to hold up one end of the shelf. Taped velcro strap holds the other end in place and makes up the hinge. It's up a bit further in the top case than I wanted. It does have a unique pull up and stow (via velcro) position. I would not recommend it as there are better and cheaper homemade possibilities.
10. EBC semi-sithered brake pads. about $135, includes shipping, to do all three calipers. Front are easy to swapout, the rear a bit more involved but should be within the skillset of most riders (especially if you do your own wrenching). I have not had enough miles to try aggressive braking, but can tell they have better bite when the brakes are applied. Highly recommended as if hard to only spend $135 to achieve a noticeable improvement in the performance envelope. They don't help you accelerate faster, but they help you stop bit faster - and stopping is as important as accelerating.
Ordered the stuff yesterday to follow in your foot steps on the mount.
I think I am using an Xmount so I can use phone or GPS. I use the phone for GPS anyway however, on my last outing it proved less than adequate when the cell signal dropped to nothing.
FYI I bought that rear trunk tray thing. For the price it is a cheap POS. I felt ripped off honestly. I installed it and took it back out. BRP for sure could have done a better job designing a tray to split the lower and upper halves of the trunk.
Bob
Bob
Lol. Yes I agree. I think we could make a better shelf
