Spyda98
At times, My Spyder will not shift to 1st gear or reverse. I have to turn off the Spyder and let it sit for a couple of minutes. Then start it back up and it shifts perfect for another 2-3 weeks. Those are the times I regret not getting a SM5.
Just curious if anyone found the actual cause and/or solution for this issue?
Side note:
-Oil is at good level. Right under Max.
-No fault codes when issue occur
-I always start and stop the bike in Neutral.
Side note:
