998cc 2011 Spyder RT continuing to Stall
dapasda
I have had the same problem I have read about from others. The bike stalls at idle. When the Spyder was purchased there was a check engine light on. Then the battery died. The following items have been done.
New Battery
Drained and filled gas tank
Ran Seafoam through it
Replaced fuel filter
Drained and filled Oil
Changed Oil filter and HCM/Transmission filter
Replaced vacuum hoses with silicone hoses
Changed air filter
As long as the throttle is applied at all, the Sypder will run. As soon as the throttle is fully released it stalls. Haven't tried replacing spark plugs and wires yet.
How does the bike run at idle? Very lumpy or smooth? Does it do it just when cold or even after it has warmed up. How many miles on the bike? Does it get ridden a lot or not so much? Does it still have a code?
If the wires and plugs havent been changed, its probably a good idea to do it. My bike was having a very lumpy idle which smoothed out after the plugs and wires but also the vac lines too. Getting to that right side plug wire is not for the feint of heart though. I ended up taking the frunk off to do it. But once that was off as well as the airbox, its a clear shot to the plug wires. There was/is a replacement air cleaner assembly that you can put on which would let you have access much easier, but that has some issues with it as well.
