Will it fit the others years also.
My thought exactly.Will the pulley retrofit??:dontknow::chat:
Jim:thumbup:
Interesting, I was noticing that on Lamont's RT the other day. It has to be a vibration dampener. Could also work as a flywheel, though a bit late in the power train for that.
Should smooth things out some.
:agree:For sure would be cool if they put that one on, we still have yet to hear on a retrofit, I can only assume it will can't believe they would change output shaft, redesigned pulley should go on but I want confirmation before I order one. Please let us know if anyone gets a definite answer:helpsmilie:Very interesting indeed. Wouldn't it be really cool if the new front sprocket that is being put on my Spyder is this one. I highly doubt that is the case, but it would be nice if it can be retrofitted to the older models. :dontknow:
Shown as two parts:
#705501201-28 Teeth Sprocket $100.99
#705501250-Flywheel $76.99
Jim:thumbup:
Sayeth Wiki:
"A flywheel is a mechanical device with a significant moment of inertia used as a storage device for rotational energy. Flywheels resist changes in their rotational speed, which helps steady the rotation of the shaft when a fluctuating torque is exerted on it by its power source such as a piston-based (reciprocating) engine" (or a heavy Throttle hand! :roflblack
If this could fit our older RS machines it would be very promising...
All 2011 RS SM5 and SE5 are delivered with this front sprocket:opcorn:
Looking at the RT and RS part #'s, there was a changeup but both models use the same shafts so should be good to go:
2010 RT sm5
420620612 Main Shaft. Serial number lower than 8458089
420620616 Main Shaft. Serial number 8458090 and up
2011 RT sm5
2010 RS sm5
2011 RS sm5
420620612 Main Shaft. Serial number lower than 8454845
420620616 Main Shaft. Serial number 8454846 and up
Shown as two parts:
