stant52
2010 Spyder Rt audio and convenience SE5.
Last year, maybe once a month, it would stick in 1st gear when at a stop. I would let it downshift by itself. To fix it I would turn the ignition off, take the key out, and wait 30 seconds; then I would drive away with no further problem.
Now this year every time I ride it happens, but it's strange. In the morning ride to work It works perfectly. I can ride it to work, sit in the parking lot, and shift from 1st to neutral, to 1st to neutral, to reverse, all with NO problem on 40 degree mornings or colder. BUT, when I ride home, same route, every night when I pull into the garage it sticks in 1st! I can't get into neutral. Also, "Check Transmission" light flashes off and on.
We were on a 3 hour run a couple of weeks ago and it happened one time. I was sitting at a stop sign waiting on the other riders to catch up and we discussed where to ride next. Then when I pulled away it wouldn't upshift out of 1st. Stopped, shut off the engine, removed the key, and rode the rest of the run with no more problems.
NOW, last week while riding home from work, I noticed the tachometer only registering about half as many rpms as what I was actually running. But this morning, the tachometer worked perfectly, and when I got to work I sat there shifting gears 10 times - 1st, neutral, 1st, neutral, reverse, neutral, and had NO problems!
So on the way home tonight, I stopped at a store, no problem; stopped at red lights, no problem; until I was almost home (I needed gas) when it downshifted into 2nd gear and stuck there. I got gas and pulled out, 1st gear, 2nd gear, then a red light; and when I pulled away from the red light it wouldn't shift, it was stuck in 1st! Oh, and also the tachometer was reading nothing, it showed zero revs all the way home!
Every time it does this, "Check transmission" light flashes. The oil level is good, recently serviced for this year. I don't think it is the paddle shifter?? It doesn't occur with the paddle shifter, it seems like it occurs only when "hot" and at full operating temperature.
I'm open for ideas from knowledgeable Spyder owners.
I have spoken to two different Service managers at two different Spyder dealers that have been in business a long time, and they were both stumped!! I'm getting ready to take it in to see if they can determine the cause of the problem. Oh, and also, last year when it was occurring, I had the one dealer hook up their computer but there were NO fault codes present.
Thanks. I like my Spyder but I'm sick of the problems. I'm thinking I'll fix it and sell it and go back to a Harley....
