2010 RSS Cruise Control Help
twrchf
Just bought a 2010 Spyder RSS SE5 3000 miles on it. It's just like new, it has the handel bar risers 4.5 inches, the ones you have to cut the origional bars and fit these on. It also has Kuryakyn grips. I am looking for a friction type (mechanical) curise control that will work with the Kuryakyn grips. Any help would be appreciated.
Cruise
Take a look at Throttlemeister. They make a friction cruise control. I have them on my bike and also a cramp buster for normal driving. Just take the end caps off the grips and install per instructions. I noticed less vibration on mine. I went with the heavy ones for this reason.
Cruise Control Installed
Just an update, I installed a Cruise Mate cruise control yesterday. They are 59.95 including the tap & die you will need to enlarge the hole in your throttle housing. I am somewhat mechanically inclined or at least I can follow instructions. The install took about an hour and the cruise works very well. I would recommend it if you need or want a cruise control. The guy that sells them is very nice and will help you over the phone should you need it. It's nice to see a quality product that works and is made in the US. :bowdown:
