Gilly
Good morning all , I have a question about the front sprocket on my 09 GS 990 ES. last time I had it out I noticed a ratcheting sound when down shifting in first and second gear. I adjusted the rear wheel enough to slip the drive belt off. I then realized the teeth on the front sprocket were stripped. My question on is the shaft, WHAT is the shape of the teeth on the shaft. The sprocket will only go on one way, there is a squared off tooth and the rest come to a point . Guess I'm looking to find out if I just need to replace the sprocket or the shaft also. Can't find a good picture of a shaft to compare mine to. I will order a new sprocket for sure... that might help. Thanks for any help.
ray:
