2009 Can Am Spyder Radiator
danielnor123
I was curious if there is anyway to modify the radiator on a 2009 can am spyder radiator to grab more air to cool the bike? Or is there anyone that makes special radiators? If anyone can help I'd be thankful.
chris t
Is it running hot? My 09 did and occasionally I could smell antifreeze. Found that the plastic radiator canister had a crack in it. Replaced it and runs much cooler.
If your right leg, or both, are getting hot, the Y gasket has failed. Replace both gaskets with Honda 18392-MAM-000.
Don't know. ..!!
At least not here. Home it would be no problem custom building anything . Have not looked to see if they even have a radiator shop that will build one for your. Say you did find one and got what you wanted made then as long as you keep all sensors and hoses you should be good ....:thumbup:
