Dingleballzz
First off, I would like to thank all the people here as I used this site to get on the road earlier. New Bad Boy air horn, wired up correctly and still works strong. LED lights, installed using advice found here.
Rear brakes pads replacement and park brake adjustment both done, and air filter and oil changed done as well.
Switched out the back tire as it was worn and was able to reinstall and align the belt properly , drove the bike for about 300km. Went out to take it for another rip, and found this. Initially began the day trying to align the belt using the tension adjustment 8mm allens at the rear. would not straighten out so moved up the bike and found this. See attached pic. Thankfully the bolt was lying there in the plastic but now I can NOT get the bolt to screw back in. I was going to use thread locker but again, cant seem to get it to bite.
Thoughts?
Have I fluffed up the inner shaft of the front drive pulley? Is that a thing.
yes I used a 36mm socket and made the front pulley flush again.
Thoughts?
