Spyder2012
Hose clamp
Thanks, and we will see if this works.
My 2012 started a slight drip under the right front side recently (that I have been aware of). Followed your suggestion, and found the screw in the one "normal" hose clamp was not even finger tight. Hard to get to, but tightened that clamp and will see if that fixes the drip. Oddly enough, the coolant resevoir (tank) is still half full. Not half empty as a pessimist might state.check the one '' normal '' hose clamp in the area. it most likely needs to be tightened. common problem, but no big deal.
