What is a Evoluzione Powerbus?
I am plannong on getting a Zumo for my ride and was going to connect it to the battery as well.
Is that not the way to install it?
apparently not.
The
Evoluzione Powerbus (enter site and click on Can Am)provides 6 additional fused power points for connecting electrical accessories. It consists of the fused power block, a relay, a 30 amp main fuse and all the wiring to hook it up. The 30 amp main fuse goes in the fuse block under the seat, is wired through the relay and powers the 6 terminal fuseblock. The relay is powered through the Spyder's switched accessory power. When the key is on, there is power to the Powerbus. When the key is turned off, the power to the Powerbus will be turned off too (after the Spyder's 10 - 15 second off delay). The Powerbus isn't necessary for connecting any electrical accessories but there are three main reasons why I got it.
1. It gives me six easily accessible fused terminals to connect power if and when I need it. I don't have to remove the panels to get to the battery when I want to connect things to 12 volts. Also, I don't have to buy and connect inline fuse holders for anything that I wanted to connect that didn't come with some type of fusing.
2. I have a common location and easy access for fuses in the added accessories power connection. I don't have to pull panels to find an inline fuse holder to check for a blown fuse if I lose power. Also, the entire Powerbus is protected by a 30 amp main fuse so if something goes horribly wrong with one of the added accessories or the Powerbus itself, it lessens the chance of causing additional damage to the Spyder or the battery.
3. When I turn the Spyder off, all my accessories will turn off too. I don't have to worry about forgetting to turn off something that may drain the battery. That's probably not an issue with one GPS connected directly to the battery unless the Spyder was not run for a long time but a GPS, radio, heated gear, etc. connected directly to the battery would drain the battery if the Spyder wasn't run for a day or two.
Evoluzione is not the only place you can find something like this if you were interested in it. It was just one of the first places that made something easily connected to the Spyder that served those needs. A few people have made some form of this by getting the components at a local store and doing their own powerbus design. I think No Magic Neon also sells a similar product.
