barb36jack31 said:I saw a posting somewhere that BRP had dropped the valve setting check until the 10K service. With that out of the way, you are looking at a 4 Qt. oil change with filter plus two O rings. Even allowing for the time to check the bike over, I would think the price should be fairly reasonable.
Jack H.
providerex said:I paid 325 for my first service.
they check for fault codes
review rpm history to check for over revving
oil change
oil filter
o-rings
check plugs
check belt tension
check brake system
Valve Adjustment is pushed to 6.250 miles
test ride the machine
hard brake the machine
took them about 2 hours
NAVYDOG said:I do not have a Spyder yet as my dealer in Ohio does not have them yet. On the issue of shim-under-bucket valve lash adjustment, it seems archaic as many motorcycles now have hydraulic lash adjusters. The 1998 Honda 750 Nighthawk I had was a DOHC inline four with maintenance free hydraulic lash adjusters. It wouldn't be that difficult for BRP Rotax to engineer hydraulic adjusters into the V-twin and eliminate the hassle and expense to owners. Just my two cents worth!
barb36jack31 said:I just found out yesterday that the dealer did NOT replace the O ring gasket when the oil filter was changed. I went to the parts department to purchase an oil filter and O ring for my next oil change. I was told they did not have any oil rings. In fact, they could not even find a stock number for the O ring. I asked what the service dept used when they did my first service and was told they did not change it - just re-used the old one. Probably no damage done. I am not leaking any oil, so I guess all is well. Sure would like to find a source for my oil changes, though.
Jack H
