Well how do I start this? So after a weekend ride I decided to give "CASPER" a bath, when I was finished I took him for a ride to blow the water off and out. I manually hit the susp. toggle to lower the firmness since I rode it two-up with the wife and noticed that the indicator d/n change. Went back to the garage and put it in gear and applied the brake and hit the switch, nothing. So I went to the fuse box and found the appropriate fuse and changed it, nothing. OHM checked the relay and found it had only 12-15 ohms of resistance which I d/n feel was excessive. Soooo I called the dealer. Took said machine in for the issue and they put it on B.U.D.S and they told me I had 33 codes (28 active & 5 inactive). They were able to clear the inactive codes but could not clear the active ones. The fix was to replace the ECM and the VCM due to the fact they were not "communicating" with each other. Parts cost is $530. and $918.00 plus 7.5 hrs. of labor ($757.00). Now riddle me this batmen, I have almost 17,000 miles on this machine and have had 0 issues, no blinking lights, no weird sounds, no drivability issues (MPG has improved also), no "LIMP HOME" modes, "NANNY" kicks in when I get a little HOT in a corner or two, Machine runs great, lights work, no issues pulling trailer, all works as advertised. Wouldn't you think if I have 2 computers not able to "talk" to each other, the machine wouldn't even start! Much less go on a 5000 mile trip with not even a hiccup. Oh and when they brought the machine back out to me the ACS was working as advertised. And they did nothing more than hook it up to their laptop!!!!! I think CASPER (wife named it) has a real ghost located within. List of codes are as follows: c006c,c0061,c0062,u0100,u0122,u0128,u0259. That's my story and I guess I'll stick with it. Just was wondering if any of you have had this problem(s)? I guess I'll just ride it until it leaves us on the side of the road somewhere then I'll set it on fire to keep me and the wife warm if we spend the night in the desert some place, I guess once were warm I could also cook a rattler or two before the fire burns out!!!
(P.S. B.E.S.T. warranty ran out on Jan 1st. of this year).
