175/65 R15
cyclekid58
Will a 175/65 R15 fit on the front of a 2014 RT, or would a 60 be better, very difficult trying to figure out what fits. Want to use a General Altimax RT43 on the front.
attachment.php
That looks like a pretty big change in tire sizes... :shocked:
RT TIRES
....Bob's chart is mis-leading ....it's meant to be, Bob likes to stir up the POT. :yikes:.....However remember this ..First off forget the Speedometer chart it doesn't apply....The Spyder uses the rear tire !!!!!......And all those other measurements should be divided in half because they represent each side of the center line of the axel................If you are at all concerned ....PM Ron Netzly of Netzly tire ....( rnet )and He will tell you if it fits......................Mike :thumbup:
Truthfully; I didn't mean to grab that portion (speedometer readings) in the screen grab...
But there's nothing misleading about the Math; as long as you know what a tire looks like, and how it's supposed to fit in place. :D
What DOES concern me: the 8.2% change in diameter. (And circumference, Mike...)
That could put you on the ragged edge"; where you start popping codes due to that big change in size. :shocked:
Hi cyclekid, I'm running 175/60R15's on the front of my 2013 RT Ltd with the 'external rib' fenders on it, and I pretty much had to change all the Hex head screws holding the fender to the frame to cup head in order to clear the tire tread at all times. So if you are planning on keeping the fenders, then I really doubt that you'd be able to squeeze a 65 profile tire in there!! :sour:
Admittedly, the 60's only touched the hex head screw heads when the tire was 'deformed' due to cornering stresses, but they touched hard enough & often enough to just visibly groove the tread surface at times. Now that I've got cup head screws fitted instead, I suspect that they might still 'just touch' under hard cornering every now & then, but the smoother cup heads don't ever leave a mark on the tread surface despite the visible 'polished appearance' that is sometimes noticeable on the cup heads themselves.
When fitting/removing the 60 profile wheels, I do have to align things up well & then very carefully lift the lip of the fender in order to get the wheel over & then onto the studs - any taller tire (like a 65 profile) & I'd probably need to trim the lip of the fender a little just to get the wheel on or off!! So with that in mind, I'd suggest that unless you are going for the 'No Fender' look, you'd be best sticking to the 175/60R15's.
The slightly wider/taller tire handles well on the road, the slightly wider footprint improves the front end grip under all circumstances while the taller profile matches the taller tire I have on the rear, and the fact that they aren't 'crappy Kenda's' has meant that I have had NO hydroplaning issues at all since they went on (altho I do run them at 16psi too, so that may be helping there). I'm running a 225/65/R15 on the rear (which makes my speedo almost exactly correct!) and that teamed with the taller/wider front tires has meant that the overall improvement in ride & handling alone is more than justification to me for the change, altho the far better mileage life from all the tires (which was the original driving force behind the change) has proven to be much better than I ever dreamt I'd achieve!! I've been running these tires (Kumho Solus KH17's) on the Spyder now for well over double (close to triple!) the distance I got out of the OE Kendas - & in the case of the rear tire, it's more like five times longer!! And like I said, the improvements in ride & handling alone justified the change, the greater tire life is all cream!! :ohyea:
Over to you!! Enjoy. ;)
I am considering a 175/55/15 when the time comes to replace my front tires. This is only .43" taller and .39" wider. I am thinking that the added width would be useful (if it isn't too wide), and by keeping the lower 55 series profile, it should still handle the curves pretty well. For the rear, I stuck with the original size, but used a kumo. With the above stated size for the front, there are quite a few options.
HEX HEAD SCREWS
....Hi, I've had various size tires on different Spyders over the years, exactly what and where are these HEX head screws that were causing interference.....??????...................Thank you......Mike :thumbup:.......PS, I believe Highwayman runs a 185/60-14 tire on the front, any thoughts on how He accomplishes that ??????.....PPS, also DustBowl has Firestone 175/65-14 on His RT-S !!!!!!
I kind of figured that there'd be some interference with the newer fenders. They fit a lot closer to the tire, than the older style. (They actually have about HALF of the clearance of the older ones.)
The newer Spyders (with 15" wheels) mainly have different fenders to those with 14" wheels - the main support spar is on the outside with the fender screwed up to it from inside the wheel arch using hex head screws - and the fender itself is a whole lot closer to the tire tread than it is on the 14" wheels!! It's the difference between the two types of fenders that make it harder to fit larger dia/profile tires on the Spyders with the new style fenders. ;)
So I have no doubt that it's possible to run bigger/higher profile 14" tires on Spyders with those older style fenders (as you pointed out, there are people doing it!!) but if you've got a Spyder that runs the 15" rims/wheels & the newer fenders like me & I believe the OP, then the fender itself is about an inch closer to the tread because it's held INSIDE the main support spar by hex head screws that leave their heads sticking out even closer to the tire tread again instead of outside that spar with the screws heads hidden. Buuut, on the 15" fenders with the spar outside & screw head projecting inside, just swap the hex head screws for dome head/Phillips head screws with a lower profile & you won't have any trouble. :thumbup:
Both style fenders are still in use...
There's not much difference in overall height or circumference between the two different tire/wheel combinations:
attachment.php
HEX VS PHILLIPS VS DOME TYPE
....I don't believe any of that matters because the relationship between the fenders and the tires is STATIC, ie. it remains constant.......and the tires never go up into the fenders like they do on a car / truck etc. .....they are like the old HOT ROD fenders, they are attached to the wheel HUBS.....I have had to remove or loosen the brackets to get some of the tires in, but once in they fit.........Of course there is a limit to what size tire will fit, but 10mm is not an issue, on either style fender...........and the difference in say a Gen Altimax RT 43 and a Continental Conti Pro ....I would rather have the General due to the much better performance numbers............jmho.....Mike :thumbup:
Believe what you like fella's, but I've ACTUALLY done this - I've fitted the 175/60R15 tires to my Spyder (175/60's that is, not the 165/55's vs 165/65's that you compared Bob) And I test fitted a whole range of different tire sizes before choosing this one; I very carefully compared the different style fenders as well, I even considered changing my fenders so I could fit different sized tires, but the cost vs benefit just wasn't there so I went with what fitted under the fenders I had.
I was quite surprised to find that the tires I did choose deformed enough under cornering forces to actually touch the hex head screws, but the evidence was there, it was clearly showing in the tread of the tire; and changing the raised hex head screws out for dome headed screws resolved the issue, altho every now & then a visual inspection shows a slight polish mark on the leading edge screw, which I reported in my earlier post.
So you all can postulate to your hearts content, I've ACTUALLY done this, I ACTUALLY run 175/60R15's on the front of my 2013 RT Ltd with the 'new' style fenders, and in answer to the OP's question, I do not believe that 185/65's or 175/65R15's would fit without either removing or somewhat modifying these fenders. In the past I've been paid to conduct this sort of testing & deliver this sort of advice, but I'm retired now, so you can take it or leave it, for what it's worth or ortherwise.... :thumbup:
Jack,
Would you do all of us a favor? :D
We're gonna need some Snickers bars; could you go get us a bunch of them?
Thanks! :thumbup:
When it comes time for replacing the front tires,( I have the original Kenda tires on the front) I am going to put on General Altimax RT43 because of the performance #'s. I have General Altimax RT43 on the rear tire. Deanna
Hi Dee,
Does the General come in the OEM sizing? :dontknow:
Altimax RT43
Hi Dee,
No this was as close as I could get, except possibly a 175/60/15 may be avail. I will most likely be sending these back, can't be returned if mounted and too expensive to do a try and see. I do have a pm in to
Netzly's to see what they have to say.
Which specific 175/60 15s are you running? Since its obviously close, the difference between manufactures real world dimensions matters here.
