OK-DZ9R
Installed a set of LED ring lights to use as DRLs using the frunk accessory circuit. On start-up, they lit as expected. However, after a short test run they had gone dark. The lights checked OK as did the fuse. Any ideas as to what the problem could be?
I considered moving to the accessory circuit under the left front panel which I found after much searching, but the wires are too short to reach. I understand there should be a GPS line on the right side - not on mine as I can tell. The accessory outlet in the tail works fine, I'm using it for my GPS.
