You do realize the frame is the same in the RT, ST, and RS. Also all the lower plastics of the ST and RS are the same?
The 1330 motor would fit just as easily in the RS as it would the ST. However, I really hope BRP does not go that route with the RS.
The RS really needs a high reving, higher hp, more of a super sport motor. 1330 sounds great and looks great on paper. However, A low rev tractor motor like the 1330 is NOT an upgrade in performance for the RS.
Now, pull the V4 out of the Aprilia rsv4 or maybe a 1300-1500 inline 4 each at 175+hp that will spin up to 12k rpm's, ....now that's an upgrade!
The 1330 could be anything they want it to be different cams ,compression ratios ,intake sizes ,fuel mapping ,head shapes,etc all could make it have zx14 power if they want ever heard of a speed triple ,take away the 200 lbs off the rt and a tractor motor would more impressive ,but does anyone think that the lawyers that wanted a burnt out tail lite to trip the nanny to only give you 40 mph would ever allow a 160 mph spyder?
Sent from my SCH-I545 using Tapatalk
