1330 - is there a Torque & HP dyno chart available anywhere?
Smolak48393
Hello - I just purchased a left-over '23 F3-T. Wondering if there is a dyno chart available somewhere like those typically included on motorcycle reviews that show the torque and HP according to RPM??
1330cc is 115 HP, for all stock motors, unless ECU has been flashed to allow more HP. Don't know the torque
So what are you trying to achieve? Wall art, bragging rights or ??? Performance questions without an objective are ... just questions.
Only dyno chart I have seen over the years is from Wick It Performance who does ECU flashing. It's many years old and zero information about it is available.
Just wanting a visual of where the stock engine makes its power, where the spikes/dips in the curve are, etc.
Not too much in the way of spikes or dips in the torque curve of a 1330 Ace motor - it's got torque out the wazoo basically right off the bat, with a bit of a bump up around 4000 rpm & then a slow tailing off above about 5500 rpm to the red-line! Power output climbs smoothly and steadily with revs to about 7000 rpm and then tails off. :thumbup:
When they first introduced the 1330 Ace motor, BRP put out a 998/1340 torque comparison graph that might help you come to grips with it... I think (hope?? :p ) I've linked it below:
https://www.spyderlovers.com/forums/attachment.php?attachmentid=197757&d=1652550145
Enjoy! :cheers:
The engine specifications tell the story without looking at dyno charts. DOHC 4-valve multi-point FI huge airbox/intake manifold oversquare 3-cylinder with 12:1 compression and balance shaft. This is a horsepower not a torque engine. Running it between 4k-8K RPM will keep you smiling.
