stewartj239
Looking at the manual, the 12 volt power outlet that is in the frunk is powered by fuse #6 (by default) and only provides power when the ignition is on. Moving it to fuse #7 will provide constant power even when the ignition is off.
I would like to power the Dyno Jet AutoTune module from what I think should be fuse #6 as opposed to drawing power from the tail light wire - which I understand is not adequate. Here are my questions:
- Can fuse #6 and #7 both be used simultaneously or is it an either or condition?
- If the answer is yes, then should I move the existing fuse from #6 to #7 for the 12 volt power outlet and use a fuse tap to tie the AutoTune into fuse #6?
- If the answer is no, then can I use a fuse tap at #6 to power the AutoTune without affecting the 12 volt power outlet?
