12 volt plug not working.
nightshift357
I have a 2015 RT limited, I'm asking for advice on how to find fuse and change it. All advice welcome.
Sent from my SM-G925V using Tapatalk
I looked it up in your owners manual. Page 152. The fuse you're looking for is in the right fuse box and can be either be fuse 6 or 7 depending if you set it up to be on all the time or switched.
The fuse is generally in the keyed power position so if you turn the key off it will not be powered. You can swap it to the other position so you have power even when the key is off.
FIRST OFF PUT A METER IN THE CONNECTION IF YOU HAVE ACCESS TO ONE, second check the connection to the plug in, third check the fuse, usually can be traced to a loose connection at the rear of the plug in. Should be fairly simple to diagnose and fix. Good luck.
