1077 brake light bulb equivalent
aka1004
I forgot which bulb I replaced brake light bulb with before as 1077 is not readily available on 2015 RS.
Was it 1157?
Thank you in advance.
The 1077 is the same double contact bayonet base, staggered pins, other than the low element draws slightly less current than the 1157.
1077 low element is 0.48 amp
1157 low element is 0.59 amp
The 1077 is typical for European applications.
The 1157 high element for stop is same amps (2.1)
The 1157 low element is 38 lumens, compared to 25 for the 1077.
If turn signals not involved, have you considered 1157 LED?
Thank you and I wanted to get spyderpops all in one, marker/turn/brake led but he says I can’t get it without strobe brake lights. I’ve been behind vehicles with strobe brake lights and found it to be distracting and very very annoying and don’t want it on my spyder.
1157 is installed and I’m good. :)
