10.25” Display, when running Apple CarPlay, no way to see miles to empty or fuel remaining - bug report filed!
mecsw500
Well-known member
It seems whilst running Apple CarPlay on the 10.25” display there is no way to see fuel level or miles to empty.
Knowing this data whilst using a maps application is rather an essential piece of data to know, especially out here in the sparsely populated areas of the Western US where gas stations can be 100+ miles apart, depending upon the route.
It should have put that data on the left hand side of the screen at least in some form,.
I filed a bug report with BRP.
Fuel level? Looks to be on the left hand side at the bottom, next to the fuel pump symbol. To the left of the coolant temp. And can't that miles be switched to Miles To Empty?
That’s odd, mine doesn’t show that.
I’ll go through the setup again. Perhaps I configured something wrong.
Mine doesn’t have anything down there.
I’m on firmware V 5.1.0, I don't know if that makes a difference, but I’m going to do a reset and start again.
Thanks for the info.
Thank you, I reset my configuration changes and started again so I see what you see.
Several other oddities were fixed too. I think I had been messing so much with Bluetooth configurations and various other things it had got a little confused.
Now it works as it should. In full screen the fuel level was showing the same level before and after I filled the tank and would only start dropping after the fuel level went below what it was when before I filled it up. Now it shows full as the tank is actually full.
Thank you for the info. I’m much happier now.
Where do you report bugs with this? I have some other issues, including that I cannot get my iPhone 17 to work at all. It works (although not fine) with my iPhone 14.
What kind of cable are you using to connect your iPhone to your Spyder?
It has to be a data cable, and not just a charging cable.
A Google search asking about CarPlay problems with iPhone 17s also questioned whether there was an active VPN client on your phone, and whether Bluetooth had been enabled/configured correctly.
I'm using an original iPhone cable. A VPN client is installed, but it is not active during this. Bluetooth was definitely configured.
When I was trying to get CarPlay to work on my 2024 Spyder I had a bunch of original Apple Lightning cables I tried with the iPhone SE I had at the time. Of all of them, I found two that consistently worked.
When I upgraded to an iPhone 16e that has a USB-C connector on the phone I obviously had to change cables, and ended up buying a Belkin braided cable that I've been using with my Spyder since that time. The Belkin cable has worked consistently and since my iPhone is mounted on a QuadLock handlebar mount, I like the idea of the braided cable being more robust than the Apple cables.
