Hi all, I went out for a ride yesterday an got less than 1 mile when my bike went into limp mode. I turned the bike off then restarted and was able to ride home. The next day I restarted the spyder and had no codes but also no tail or running lights. Checked all fuses and they were all good. Can anyone help. OnVentures
Do you have a wiring diagram?
Fuse #7 is OK you said.
I would start by checking for voltage- at the fuse(1-FB1-B7)red/yel wire,
at the "input" side of the ignition switch(can't read connector info)red/yel wire,
at the "output" side of the ignition switch, orange wire(switch must be on) this wire goes to JT(junction terminal?) which feeds - marker lights, tail lights, license plate light,brake light, an input into the VCM.
i'm thinking it's got to be something common to all components not working.
Loose connection, wire....
Get your ground connection, for your meter, from under the seat.
I don't think it's a ground problem, as each component has it's own ground connection. Unless they all meet in one spot on the frame(I don't know where that is! I'm hoping Scotty will enlighten me!)
Please let us know what the problem turns out to be,
Bill
