Originally Posted by markyodo
Very good news, thanks again for doing all the work. I forgot about the trailer. I intend on having a trailer for the RT by June so looks like I would want 6 sensors.
The way I understood Bluetooth communication, the device randomly chooses from 79 available "channels" to communicate. It has a set time to make it's communication before it uses another and it does this random selection @ over 1000 times per second. So unless you have all channels being used at all times it would be difficult to cause any interference.
I am thinking my interference issue was caused by a strong BT signal masking out a weaker one. It may have been sidebanding. No way to tell what device uses what channel.
Great thread. I think I'm going to order 5 for my RT and trailer. Bob, thank you for blazing a trail on this!
--Rod
Another question Pioneer Bob:o) Say you have the three sensors for the bike and they are set up and work fine. You are towing the bike in a trailer. Could you take the front 2 sensors from the bike and put them on your trailer(2 wheels) I assume that they reset to the different pressure in the trailer tires and then you are good to go.
Other than being cheap, do you think that this will work?
Yes you can do that but if the pressure min and max need to be changed then you have to release them change the settings and rebind them. At the point might as well add another vehicle and the rebind to that.
The FOBO web site has excellent videos for moving the sensors to different vehicles.
Bob
Just checked Play Store, FOBO Bike not there. Sent them an email asking when Android users may see app. Sure looks like what I have been wanting in aTPMS app.
2014 RT Ltd Silver Platinum Satin, Ultimate Seat, rider and passenger backrests, Vented Windshield, Adjustable Side Wind Deflectors, Chrome Tri Axis Handlebars with GPS Support, Trailer Hitch Kit, RT-622 Trailer Silver Platinum Satin, Stebil Air Horn, BajaRon's Sway Bar, Spyderpops Bumpskid bike and Trailer, R/T grills, SpyderSisters Front Trunk Pockets, SpyderSisters Sunshade, Spyderflaps Mud Flap, many TricLED lights
I just downloaded it. You must have mistyped or something.
Found it. Initially searched for TPMS. This time I searched FOBO and got it.
Great information! Looks like you and Phil have both named your Spyders 'Darth'...
I just got confirmation from FOBO support, which BTW is great. You can buy the FOBO bike set plus one for the rear wheel install on the Spyder and all is as previously stated. When you are towing the bike on a trailer, you take the 2 off the front tires and put them on the trailer tires. You do not need to disable them when transferring them. You will need to reset the new pressure desired.
No need to buy an extra sensor just buy the right kit here ya go
http://www.ebay.com/itm/181694937904...%3AMEBIDX%3AIT
OK so understand though. While you do not need to do the process I said step by step let me clarify what happens.
If you go into the APP and change the tire pressure and click "done", the FOBO APP tells you to unscrew the sensor and wait 8 seconds. Then it tells you to screw it back on. What it is doing is basically the same thing, e.g it is unbinding and rebinding the sensor.. When you unscrew a sensor for more than 8 seconds it basically turns it off. The sensors turns itself on when you screw it on and it senses pressure. So again same thing.
So it is not just as simple as you say although this process the APP takes you through to change the pressure settings is quite easy.
So just to clarify. I did in fact test this and that is what you do.
Bob
Originally Posted by Magdave
Same thing. fobobikesales. That his Ebay page. So either way works.
Difference with the ebay ad is when you checkout be sure to send a note in the "notes" box what color you want.
If you do it from his website, then your order FOBO bike and order 1 extra sensor. works out the same price.
Bob
Fobo TPMS are now installed on my Spyder. Total install time is 20 minutes including air ajustement prior the installation of the TPMS. It's very easy to install when following the instruction of Bob (Finless). I also made one test with the apps by reducing air pressure of the front right tire and I heard the alarm in my helmet equiped with SENA SMH10. This is my results:
A couple days ago the iPhone FOBO app was updated. It added a 2 wheel trailer and a 4 wheel trailer. I expect another update soon for the air shock bag.
Android I cannot speak to as to its update as I don't have a android device on 4.4 yet.
Bob
If you have been playing with your FOBO system, you will see that you can mail yourself a log. Right now the log is nondescript because they were just using it for trouble shooting. Here is what I figured out. It's an Excel spreadsheet, so if you have Office or a MS reader, you can check this out.
This is the link: You tell it to open the file with Excel, or you can save it too if you want.
http://williampitzer.com/FOBO.xlsx
So if they are adding the trailers, does the app allow for multiple "vehicles"? Like 1 screen for the spyder, swipe for the trailer, swipe for car/truck?
Yes it does.
Bob
say I have 2 spyders (1 for me and 1 for wife)...
I can get 1 set of 4 sensors and install with my phone on my spyder. Take readings and inflate/deflate as necessary. Then I can remove the sensors from my spyder and wait at least 8 seconds. Remount them on my wife's spyder in the same spots they were on mine and take the readings for her spyder.
Should work, right?
Because after Spyderfest, my farkle range is VERY small!
Should work, right?
Yep!
Bob
Mod Monster
REALLY great find Bob!!
Does the app allow setting alerts based on pressure/temp levels? And I mean iOS alerts that come across even on lock screens?
____________________________
Phil - Tyler Texas
2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
Hey Bob did you find out if the sensor will fit under an Ultimate seat without getting smashed yet?
Since I want it all...
I'd like to be able to monitor 3 and/or 5 tires for when I do and don't pull my trailer.
Also, can I synch my iPhone bluetooth to both my Garmin GPS AND the Fobo unit?
2020- RT Limited
Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Big Bike Parts wiring harness
Permanent Smile!!!
Yes, the FOBO unit uses an APP to communicate over Bluetooth. So to your phone it is a different device type than your GPS. So no issues.
Bob
