Ram Mount Options for ST S
I have a 1350 Garmin Nuvi and trying to find a handlebar Ram Mount. Looked on their site and not sure which handlebar mount will fit. They have clamps that fit around the handlebar as well as bolt mounts. Which ones will actually fit on the ST.
I believe the ST has a similar 3 bolt handlebar as the RT so do some forum searches for RAM mounting options. I'm sure you will find a lot of options.
I have the RSS and after much buying, testing, and searching the best RAM mount option for me was the: RAM-B-108BU . I'm sure this option will work for the ST as well.
Good Luck
http://www.spyderlovers.com/forums/s...ball-mount#top
Marilyn 2023 RTL Red
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
"common sense will prevail....but we see no sign of that"
I use a Rivco drink holder mount with RAM part and RAM X-Grip.
Lamont was developing something at one time that would allow multiple ball mounts to be screwed into it but I haven't seen anything on it in several months.
ram mount attached to handle bar bolt
I changed one of the handle bar bolts to a stud and mounted a ram ball .copied someone else on the site has worked well . would post a pic but bike is in the shop
please post a photo
please post a photo when you get a chance sounds like what I want to do
this might be easy option
this is what you want
RAM-B-367U ( just do a google search)
just pull out one of the bolts first and check if our handle bars use a 8 mm or 10mm bolt dont recall
Its 10mm
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
I bought the RAM mount and it works well. One problem, the kit came with a STEEL bolt and it shows RUST. 2013 ST-S with a 4 bolt steering head
