Vee Rubber Tires
Has anyone used Vee Rubber VTR-350 Arachnid tires and if so, how have they worked for you. Any handling or smoothness issues ??
Thanks for any info.
Don't know..!!
have not heard much. They looked good and I believe Ann (squared Away) had a set for a while. Then there was a spec issue but would like to hear from those that had used them...
I just mounted a set on mine and hope to get good results. Worth a try, OEM too expensive.
Really? Ohsnap.....
I put a pair on the front of my 08 GS and although I only have about 500 miles on them I have no issues other than I had to take one of them to a tire shop to get it to seat.
I had an Arachnid on the rear and I got about 8,000 miles on it. I believe that they (Zee Rubber) are working on a new compound/tire as the original one was not rated for the weight of an RT. While some people had issues with the tire slipping on the rim, I had no problems with the one that I had, and it handled great much like a Kenda in that regard. I currently am running a Kumho on the rear and I do not like it in the rain but as many of you know, they will last more than twice as long as a Kenda.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
ANN
What is your issue in rain have on rear of my ST-S and have not noticed anything?
Originally Posted by bamaspyder1
ANN
What do you have on the front? I have Federal Evos on the front and the Kumho on the rear and I hydroplane a lot.
2010 RT- 622
Maybe you need to slow down in the corners
