Unlocking Seat
I just had the Comfort Seat with backrest installed a couple weeks ago (LOVE IT). Is there a way to permanently have the seat so it is not latched, so I don't have to use the key every time to unlock the seat for fueling?
Phil
Yeah..!!
check a thread just posted by Blueknight 911 or click here...http://www.spyderlovers.com/forums/s...-ANNOYING..you can also remove the latch...
Just occured to me that if you fill in the knotch on the pin (tape over or insert a spring clip) this would prevent the latch from ctching...
Phil
Raise the seat and look at the latching post. take a cresent or small wrench and loosen the jut on the post and it will fall into your hand. takes about 1 minute. Mine has been that way for a year or so. the seat is not going to go anywhere without the latch, you and gravity hold it down anyway. Don't have to fool with the key to put gas in.
Happy Spyderlovers
As posted, just remove the pin and your worries should be over. Some also remove the shock, if the seat is not heavy enough to hold things down when you are not seated.
I removed the housing the pin goes into and tucked it in a hole somewhere. The pin is still in, also added some Velcro under the seat
