Results 1 to 21 of 21
    Jul 2011
    Kresgeville PA
    Default Just got it back from service!
    Not sure if I am missing a plastic under tray. The photo is taken from under the front of the bike, looking towards the rear. Just behind the skid plate should there be two under trays one on each side of the main frame or just one as in the photo? Not sure if one was left off by the tech.
    Also got a nice gouge across the nose while it was at the dealer for recalls and bulletins.
    It is a 2013 STS .
    Aug 2013
    Richmond, B.C., Canada
    Sorry to hear about that. I always ask the dealer to inspect mine and mark any (if any!) discrepancies when I bring it in for service.
    This way, I can prove any new damages/scratches were cause by them. Always do a careful 360 degrees inspection before leaving the dealership.
    Once they know you are "anal" about your ride, they tend to be more careful.
    Dec 2012
    Murphy, NC
    Default Tray
    Yes you are missing a tray and that is a nasty gouge on the front. But many of us remove both trays under the Spyder. It helps dissapate the heat and makes oil changes easier.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Mar 2012
    Beaverton, Oregon
    The damage looks as though it was ridden onto a steep lift without enough clearance! the panel is indeed missing but i took mine off two years ago.
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Default Bummer..!!
    You are missing the pan and though many remove them you still should get it back so you can decide. The scrape along the nose is unfortunate and you should point it out. Not a good sign as to the work they perform...make sure you check your fluid levels..!!
    Jul 2011
    Kresgeville PA
    Thanks for the replies. I plan to try and get the dealer to replace the nose cone, As I don't think the gouge is repairable . The under tray that is missing is under the steering area and not the oil tank. I don't want to disclose the name of the dealer until I see how they are going to handle this.
    I had the buds update for heat done and really can't tell any difference in temp or performance on the ride home.
    Good Luck! Please let us know how they respond to this...
    May 2009
    Connecticut
    Quote Originally Posted by Jesse View Post
    Leave that tray off as it helps air escape under that Hot Master Cylinder side! I would get the tray from them in case you sell it or trade in.
    Best to take the one off under the oil filter also if you have the ability to do so?
    Sea Doo GTI-SE 90 Jet Ski!!
    red oak, tx
    Dang, when I first looked at the gouge I thought it was at the bottom of the front. Now I see it is on the trunk lid. Somebody hit something or ran something into it. good luck at the dealer.
    Jul 2010
    kansas ottawa
    i got both my pannels off the bottom it runs cooler that way,but thats up to you.
    Keep us informed. Give the dealer a chance to make good. Things like that need to be made right--IMO.
    May 2013
    Edmonton Alberta, Canada
    Hopefully the dealer will work with you on that gash on your front end.
    My dealer has a policy that in your presence they take multiple pictures of your Spyder plus write up an inspection list whenever checking it in for service.
    Protects both party's...
    2014 RT-Ltd , Cognac
    Aug 2013
    It is a 2013 STS .
    Jesse, those that responded to this thread so far apparently don't know their STS's.....if they even own one?
    In your pic, the lower panel to the left that looks like it is missing is acually coorect, there is no panel there from the factory.
    I am guessing because of the air intake on that side, but there is no panel there!
    Now as far as the scrape mark....I would suggest getting a set of Fox shocks off eBay and the BajaRon swaybar!
    Jun 2013
    Fleetwood, PA
    Default Good catch Snoopy!
    Quote Originally Posted by SNOOPY View Post
    I was just going to reply! There is no panel in that location. First thing I noticed when I installed my new sway bar.
    Learned something new about the oil change panel today.
    Aug 2013
    Quote Originally Posted by warp10 View Post
    Oops, i thought it was lower too when I first looked at it.
    Jul 2011
    Kresgeville PA
    Default Dealer steps up to the plate
    Below is the email I received today from the dealer after I sent them the photo of the gouge on the nose. As you can see this dealer provided a no hassle replacement of the nose cone and I think this is the way dealers should treat there customers. Kudos to Blackmans Cycle Center.
    Hello Jesse,
    I do apologize for the gouge, had I seen it before you left I would have taken care of it then. I have a whole new nose piece on order for you, we will install it when you bring machine back for the cruise control switch. If you have any question please feel free to contact me.
    Thank You
    Jason Harrington
    Blackmans Service Center
    Jun 2010
    Las Vegas
    to your dealer for doing the right thing. But for everyone else who may have a dealer that isn't so honest, you must be sure to go over your Spyder with a fine toothed comb each time you pick it up from service. Check for loose panels and paint mars.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Bryant, Arkansas
    Sounds like the dealer is going to take care of you.
    Cruzr Joe
    Sep 2012
    Virginia Beach, VA
    Default Way to go!!!!
    Hello Jesse,
    Thank You
    Jason Harrington
    Now that's a dealership you can count on!!! Just out of curiousity...how did such a big gouge happen in that particular area?? I'm sure you got your point across to the dealer, but I would also make it a point to let him know that there may be a need for concern for other Spyders that come in for that particular service. Maybe there is an area within the shop that has been known to produce that same type of damage that is unknown to the dealer. JMHO
    Glad to hear of another pro-active dealer when it comes to customer service.
