![Quote](images/misc/quote_icon.png) Originally Posted by jthornton
Here is the prototype installed on Doc Riverside's RT, we also tested on a ST for fit.
I really need to thank Doc Riverside more often for all his help over the last few months as we tested prototypes and worked out details. And thanks for Dan for his testing with the GS/RS.
The production version will be anodized.
JT
How is this different from the Kewl Metal airbox conversion?
![Quote](images/misc/quote_icon.png) Originally Posted by DR Buck
It uses a larger filter with 30+ cross matches so easy to find come replacement time. The crankcase vent is done in a manner that won't allow any oil to get on the filter and evenly divide any return oil to each cylinder. The mounting holes exactly match the metric bolt pattern of the throttle body for a perfect fit. It's built in 3 pieces to minimize waste of material. It has the Doc Riverside and WackyDan seal of approval .
JT
jthornton,
What is the price? I went to the link and couldn't find one
Jerry
![Quote](images/misc/quote_icon.png) Originally Posted by spacetiger
jthornton,
Jerry
I have not set the price yet, I'm still working with the anodizer on what my cost will be for that. As soon as I get firm pricing I'll post the price. I try very hard to price my products very competitive and either make them myself or they are made in Missouri. I should know next week the delivery on the first batch and the price.
JT
I'm in Australia and I'm very interested. Could you put me on your list.
I,m figuring 3 Years till the Iridiums my 2012 RT came stock with need replacing.
Even if you can reach the front plug would not you need to remove the air box to run the New wire for it??
We all know you should do new wires with plugs?
PS: That's why I like the simply GS and ST is similar if they have solved the heat problem on the 2014 ST?
Sea Doo GTI-SE 90 Jet Ski!!
![Quote](images/misc/quote_icon.png) Originally Posted by JRWW
You bet!
JT
New wires.
Well got the front spark plug out, and new plug wires arrived yesterday hope to attempt to replace the wires tonight, still haven't gotten the air box out, hopefully I can finish without doing so, but it is now a priority mod to replace that monster. I am just amazed at the stupidity of building a state of the art $30000 dollar touring machine, and then not making sure the average person can maintain the basics, and to top it off using cheap parts that only last 9 to 12 thousand miles before having to replace them.![banghead](images/smilies/banghead.gif) ,unless they make major changes in the ease of maintenance of these bikes this will be my only spyder, I love the bike but servicing them is ridiculous. O and how did I decide that plugs needed changing? the bike through the P0174 code and my dealer suggested changing the plugs before I brought it in, because according to him today's crappy gas fowls the plugs, now I know why he suggested I change the plugs geese thanks LOL.
Sorry about the rant just had to get it off my chest, Thanks for all the great help on here and I promise not to do any thing rash LOL
![Quote](images/misc/quote_icon.png) Originally Posted by yamahog
Well got the front spark plug out, and new plug wires arrived yesterday hope to attempt to replace the wires tonight, still haven't gotten the air box out, hopefully I can finish without doing so, but it is now a priority mod to replace that monster. I am just amazed at the stupidity of building a state of the art $30000 dollar touring machine, and then not making sure the average person can maintain the basics, and to top it off using cheap parts that only last 9 to 12 thousand miles before having to replace them. ![banghead](images/smilies/banghead.gif) ![hun](images/smilies/huh1.gif) ,unless they make major changes in the ease of maintenance of these bikes this will be my only spyder, I love the bike but servicing them is ridiculous. O and how did I decide that plugs needed changing? the bike through the P0174 code and my dealer suggested changing the plugs before I brought it in, because according to him today's crappy gas fowls the plugs, now I know why he suggested I change the plugs geese thanks LOL.
I went through the same thing with my 2013 RTS SE5 and the P0174 code. I also replaced my plugs and wires with BajaRon's set. I had previously removed the airbox and replaced it with the Kewl Metal air filter kit. I did not get rid of the code until I removed the fuel canister and isolated the purge valve. I rerouted the gas vent to the back of the Spyder. Look for the threads on performing a canisterectomy. That solved the P0174 code issue. The problem was the purge valve.
2013 RTS SE5
2013 Kawasaki Vulcan Nomad 1700
![Quote](images/misc/quote_icon.png) Originally Posted by Huddleston
Purge valve failure or a vacuum leak is far more likely to cause a lean cylinder condition. Other possibilities would be a valve problem or an O2 sensor issue. There are additional possibilities. A fouled plug should not cause a lean cylinder on a vehicle with individual O2 sensors...just the opposite, so I don't understand the tech's comments. Sounds like he was shooting from the hip (and didn't want to bother taking three hours [flat rate] to change the plugs on an RT).
Thanks for the info I was afraid of that the first time I got this code they said the throttle stop had to be reset that worked for a year or little better, If the plugs dont fix it it is going back to dealer, and he better fix it while its under waranty is all I have to say about that
been a while
When I replaced the plugs and wires, was able to leave air box alone and reach around the front of the motor to get the plug. Also, rerouted the wire around the front of motor to the plug on the right side .
replacement filter
Add me to your list for the replacement filter. Working around that air box is ridiculous. Thanks for spending the time designing and manufacturing it. I work with a good anodizer up in Minnesota if you would like a quote from there I can arrange it. Shipping is the only drawback. Mike
![Quote](images/misc/quote_icon.png) Originally Posted by MMcc
Hi Mike,
If you want to PM me your email that will make it easier to contact you when the first batch comes back from the anodizer. I have a company in Missouri that will anodize the parts for me. Thanks for the offer. I actually have an anodizing line part way constructed but to speed up the first few batches I'm going to farm that out.
The air filter housings are being made at my friends machine shop as we speak. He has a much bigger machine shop than me so I get him to make many things for me.
JT
So disapointed in my dealer.
Thanks for the info I was afraid of that the first time I got this code they said the throttle stop had to be reset that worked for a year or little better, If the plugs dont fix it it is going back to dealer, and he better fix it while its under waranty is all I have to say about that ![Gaah](images/smilies/gaah.gif)
Up date to spark plug saga, the plugs not only didnt fix code but after putting everything back together I fired up the bike and O my god someone droped marbles or something down my intake, was my first horified thought, the bike ran much rougher and sounded like it was hamering its pistons to death , so I quickly shut it down and called the dealer, he was like wtf did you do put in the wrong plugs are they too long? so I tell him the plug numbers and he say's on man those are wrong for your bike anyway I trailerd it to them and three hours later its done, they said plug number DCPR8EIX was wrong for these bikes and messed up the computers throwing all kind of codes, so they had to reset everything and replace the plugs, its my fault for useing wrong parts and that will be $176.00 we gave you a brake and only charged 1 hr labor plus plugs, at this point I am about to explode, I asked them what about the lean code and fouled plug that started this mess and they where like its a motorcycle we have them foul just moving them around the shop, so i asked what if the plug fouls out in the midle of nowhere 2 to 3 hundred miles or more from a dealer and he just said I am **** out of luck.
So whats the deal does just changeing plugs mess up the computers on these bikes are these the wrong plugs or is my dealer just screwing me?![chat](images/smilies/chatchairs.gif)
Up date to spark plug saga, the plugs not only didnt fix code but after putting everything back together I fired up the bike and O my god someone droped marbles or something down my intake, was my first horified thought, the bike ran much rougher and sounded like it was hamering its pistons to death ![yikes](images/smilies/22yikes.gif) , so I quickly shut it down and called the dealer, he was like wtf did you do put in the wrong plugs are they too long? so I tell him the plug numbers and he say's on man those are wrong for your bike ![banghead](images/smilies/banghead.gif) anyway I trailerd it to them and three hours later its done, they said plug number DCPR8EIX was wrong for these bikes and messed up the computers throwing all kind of codes, so they had to reset everything and replace the plugs, its my fault for useing wrong parts and that will be $176.00 we gave you a brake and only charged 1 hr labor plus plugs, at this point I am about to explode, I asked them what about the lean code and fouled plug that started this mess and they where like its a motorcycle we have them foul just moving them around the shop, so i asked what if the plug fouls out in the midle of nowhere 2 to 3 hundred miles or more from a dealer and he just said I am **** out of luck.
So whats the deal does just changeing plugs mess up the computers on these bikes are these the wrong plugs or is my dealer just screwing me? ![chat](images/smilies/chatchairs.gif) ![don't know](images/smilies/shrug.gif)
no way..! dealer BS'n you. sometimes I wonder if these spyder techs are even qualified to work on
Plugs
NGK Iridium Spark Plugs for all Spyders through 2013
DCPR9EIX (Colder Plug) - RS/GS/RSS
DCPR8EIX - (Hotter Plug) - All RT's (Can be used in all Spyders)
●Info sourced from Bajarons site.
Your dealer is a crook and an idiot, IMO. What plugs did he use? The ones you used are perfectly suitable. I suspect what you did was fail to connect a plug wire correctly, or knock off a vacuum hose or sensor wire. Be sure to use heat sink compound on the plug threads, too. The problem was undoubtedly in your installation, not the plug used...provided the gap was correct. Running on one cylinder, misfiring, or preignition can sound like the engine is ready to come apart. Preignition from running lean or from carbon deposits will, too. The Spyder should not foul spark plugs. If all the dealer's Spyders do so, they are screwing up a lot of them. Causes for repeated plug fouling include bad plug wires (most common), bad coil, or faulty ECM or ECM connection. If your code remains, you still have the original problem. Find another dealer and attack it again. Sorry that yours is such a dud!
But?
![Quote](images/misc/quote_icon.png) Originally Posted by Jerbear
Thats where I got the info for the plugs, but it did run worse and he says all he did was put brp recomended plugs in and reset codes, so what does everyone think he realy did to it.
P.S. I did not get plugs from Bajarons I allready had them in prep for when I needed them, I did get his wires thow.
P.S. I did not get plugs from Bajarons I allready had them in prep for when I needed them, I did get his wires thow. ![chat](images/smilies/chatchairs.gif)
If you also installed Ron's plug wires, my guess is that you failed to get a connector all the way seated. The boots sometimes make this difficult. The only thing the dealer did differently was possibly install a non-iridium plug. BRP initially specified the cheap version of the plug. That would make no difference. He probably just got the wires seated properly in the process. No difference in iridium vs. regular as far as heat and suitability are concerned, but the iridiums last longer. I hope the crook gave them back to you. I'd still be interested to know exactly what his "recommended" plug was. Unless your plugs were mistakenly not what you thought they were, they were fine to use.
![Quote](images/misc/quote_icon.png) Originally Posted by NancysToy
Thanks for the input I am haveing my douts about my dealer, they havent even heard of the spyder 5, I thought that was weird for a dealer who has been selling these bikes since the start, problem is I dont have the time to take the bike 200 miles or more to the next dealer especially since I would probably have to leave it for who knows how long for them to work it in, I have no codes at this time and will most likely have to make a desision soon as to weather I want to keep it or not, the whole idea of us getting this bike was to take long trips in another couple years when we are able to retire, and I dont feal I can trust the bike or the dealerships even though I really love rideing the RT.
Thanks for the input I am haveing my douts about my dealer, they havent even heard of the spyder 5, I thought that was weird for a dealer who has been selling these bikes since the start, problem is I dont have the time to take the bike 200 miles or more to the next dealer especially since I would probably have to leave it for who knows how long for them to work it in, I have no codes at this time and will most likely have to make a desision soon as to weather I want to keep it or not, the whole idea of us getting this bike was to take long trips in another couple years when we are able to retire, and I dont feal I can trust the bike or the dealerships even though I really love rideing the RT. ![Frown](images/smilies/frown.png)
I think you will be fine for now. Give it a few 100 mile runs, then stretch it out a bit. If all remains well you should be in for thousands of trouble free miles. Your dealer may be a crook, and poorly informed, but they got you running right with no codes. Try to put this all behind you and start over fresh. When you expect good things, they usually happen.
Sorry to hear you had problems with sparkplug replacement
I agree with Scotty, your service mechanic/dealer is a crook to pull that on you; (running on one cylinder makes all kinds of mechanical noise).
you probably did not push the sparkplug wire boot over top of #1 sparkplug far enough for metal contact to go on sparkplug contact.
I use a silicone grease inside wire boot so it will slip over top of sparkplug.
What did your old plugs look like that you removed? Was #2 sparkplug a little white looking? What was your old sparkplugs DCPR8EIX?
You had the correct Iridium sparkplugs you installed!!
A good mechanic would have checked the plug wire connection before removing your new Iridium plugs!!
I feel it is your canister vacuum purge valve not working, causing your RT to run lean.
Just remove gas canister & put a gas filter inbetween gas tank vent hose & drain hose. Then put white seal tape around threads of bolt & screw it into vacuum purge hose.
You can see head of bolt in the purge hose, in photo.
Anyway enjoy your long rides. I put 22,000 miles on my 2011 Spyder RT-S SE5!!!!
Jim
You bet!
JT
Hi I also live in Australia and I am very interested in you air filter can you put me on you contact list also
Thankyou
Robert
![Quote](images/misc/quote_icon.png) Originally Posted by wtwing15
Thankyou
Robert
Got you on the list.
JT
