Your Seal's came with a 3/4" aluminum shim between the brake and rubber pad. Did we fail to put it on? Let me know. If you have the shim, and still want it higher, try putting some washers under the shim. You can raise is as much as you want. You may have to buy some longer bolts if you go too high.
Ride in comfort,
John
Seal Floorboards
