Results 1 to 16 of 16
    charleston, wv
    Default Help and Information
    We own a 2012 RT. We now have five thousand miles on our bike. We have read a lot of discussion about the elka shocks. What advantage would we have to replace the original shocks on our bike with the elkas?
    Jun 2012
    Fairmont, Minnesota
    The general opinion seems to be that they are a great improvement. However, I think how you ride would be just as much of a consideration as anything else. I have a 2012 RT Limited and have set my shocks to the fourth detent and find them to be everything I need. There is no way that I could see enough additional improvement to spend the kind of money that the Elkas command. However, if you are an aggressive driver, they may be money well spent.
    Dec 2009
    Canada
    Agree with everything rc said. Heavier shocks, such as the Elka's, will reduce the body roll during aggressive cornering. Cranking your stock shocks up to 4 or 5 will give you a stiffer ride and reduce body roll in cornering.
    I found the biggest difference with the change to the Elkia Stage 1R+ front shocks was observed during highway driving in heavy winds. I found the RT to be much quieter as a result of the addition of these new shocks. Mind you, I was running with the much weaker 2010 RT shocks.
    Sep 2011
    North Central Illinois
    Your overall body weight (especially if two-up); and luggage can be a consideration as to whether you will like (or need) a "stiffer" shock.
    If you are equal to, or exceeding the weight limits of your RT, then a stiffer-shock may help improve your Spyder's handling.
    Just an added thought to consider.
    (Personally, stock shocks of my 2011 are fine for me (set on 5); with the read air shock set fairly high.)
    Mar 2012
    Beaverton, Oregon
    I have the Elka shocks on my bike and love it. I have just added the new BajaRon sway bar and the difference is night & day. Both are great but if you do not ride aggressively, the $200+ sway bar will probably make the difference you are looking for. That said, both make great riding and each have added benefites, so if the $$ is not a great concern -- go with both.
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    charleston, wv
    95 % of our riding is with two people. When we first got the spyder we were afraid we made a mistake once I turned the shocks up to 5 we liked it a lot better. West Virginia interstates are more curvy and uphill than most flat land interstates. That is where I am having the problems at seventy miles an hour.do i sell and get the 2013 model so i can get the running boards and better suspension?
    If you don't think there is a problem, then nothing needs fixing. I would not spend the extra money unless I felt I had to change the shocks for better performance.
    This is a difficult question to answer because most people don't have the option to try before they buy. I never considered a heavier sway bar until I got comfortable riding my RS. Then I found the Nanny to be extremely annoying and the wheel lift/body roll to be excessive. Just when things started to get fun in the twisties the Nanny would say; 'Oh no you don't'. And really, with the way the Spyder dove and leaned in the corners she was probably right.
    When I first installed the upgraded sway bar I seriously doubted it would do much for me. I was hoping for at least a noticeable (even if only barely) improvement. I have to admit, I was blown away. I never expected one mod to do so much for the Spyder. It was amazing! I was going faster and it felt slower because of the reduced body lean and increased control. The Nanny was much happier as well.
    So, happy as a clam with my new sway bar I thought I was satisfied until one day I rode another RS that had the custom sway bar installed, but also had upgraded shocks. I was again impressed with the improvement and realized I simply did not know what I was missing!
    Some of this depends on how you ride. But if you encounter strong cross winds or ever need to make a sudden, evasive maneuver these upgrades will certainly be appreciated.
    What has been said here is completely true...
    Now the question that you'd need to ask yourself is, "Do I ride aggressively enough to warrant a shock upgrade?
    (For the record: I put 2011 shocks on my 2010, and have a BajaRonBar in the garage awaiting installation...)
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    I found riding over rough roads with my Elkas compared to the stock shocks was like night and day. I hardly ever bottom out with the Elkas and was often enough with the stock. I had them installed a SITA and took it down the rode over some railroad tracks and deliberately hits some bumps and noticed the difference immediately! Best mod I have done so far, and I would imagine when I order my BajaRon sway bar early next year it will the next best mod and will complete the front end. You will not be dissapointed!
    2012 RT , stock Lava Bronze
    Jun 2010
    Las Vegas
    If money isn't an issue I'd put on the Elka's and a Baja Ron Sway Bar. But if cost is an issue maybe you should start with the sway bar and see how you like it before you add the shocks. I have a 2010 RT with 2011 shocks and I just put on the sway bar and the difference is amazing.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    washington state
    I'm a sensible rider, I don't ride my like a thrill seeker,cornering like no tomorrow with one wheel on the air and do the impossible wheelies. . We all have different idea how to ride, and we tailor our self and our accordingly. Ride safely and God Bless.
    Hanover, PA
    Default Wanting Elka's
    We have 2011 RT and ride two up about 95% of the time. I have my shocks set at 5 and noticed a difference. I am going to order a pair for Spyderfest (where ever it will be held). I can't wait to order them. I am not very aggressive so I think I will be getting the Stage 1. Can't wait!!!
    I I have a 2010 RT with 2011 shocks and I just put on the sway bar and the difference is amazing.
    When you got the RonBar nailed in place; did you dial back your preload settings?
    Mar 2009
    Beavercreek, Ohio
    I had the Elkas put on at the BBQ, a 2010 RT. I think it makes a difference for a not fast ride. I felt the difference going the grass hill. At the same time, I hear the later RTs had much better shocks. Might depend on the year of yor Spyder
    Oldmanzues
    Mar 2012
    Beaverton, Oregon
    Re riding style: When I first had some Elkas delivered (not from a sponsor) they came set up wrong for a much heavier load. Len from Cowtown reviewed the springs and settings and told me that they were way wrong. I liked the cornering but they rattled my fillings. I returned them, got proper ones from Len and installed them. They rode much better and I called Len and told him that I liked the cornering better on the heavier setup. His response was that often folks ride much more aggressive that they thought. I cranked the springs down 3 turns and upped the rebound 8 clicks and liked it. Now I have the new sway bar and I have returned the shocks to the original settings and the ride is comfortable and the cornering is like it is on rails! I certainly AM a more agressive rider now with a properly setup front suspension!
