harborfreight 1500 lb motorcycle lift
Has anyone used this to lift their Spyder?
http://www.harborfreight.com/1500-lb...lift-2792.html
There is a coupon selling it for $69.00. So I am trying to find out if it will work.
I think ted and dave have one of these, PM clincyspyder.
Has long as it goes lower enough to fit under the spyder I would have thought it would work fine.
harry
I sure hope so
I just bought mine a week and a half ago and expect to use it tomorrow to install the Bump/Skid mod. I expect it will work - I sure hope so.
Thanks Harry but there is no clincyspyder listed in the members and a search for that user name comes up with your post as the only listing.
it looks pretty good where did you find the coupon, I was just on the web site and it was going foe $99.99?
In several of the magazines we get for free.
I have this lift, it works great. Tools are always hit or miss from Harbor Freight. This lift goes on sale alot.
Hint: If you get it, the release pedal will lower the lift slowly if pushed all the way down and faster if just lightly pressed.
Sorry my bad spelling CyncySpyder Not that you need it now others have answered
harry
I use this same lift and also bought it with a coupon at Harbor Freight. It works great but you have to be careful to ease it down or it will drop your spyder faster than you can believe
I shortened most of the handle on mine so I could store it under a workbench.
Thanks for this thread! I've been looking for something like this for my spyder.
Would there happen to be a coupon code on the coupone that can be entered online?
My coupons say they are for In-store use only, plus I think the shipping on this would be prohibitive. Best bet is to find a H/F store.
(many magazines include this coupon)
The website says it has standard $6.99 ground shipping option on all orders, so I put the lift into the cart and entered coupon code 99094294 in and that brought it down to $79.99 (couldn't find a coupon code for more than 20% off). That's still not a bad price if you don't have a store nearby, or it's inconvenient to get to.
I've had this lift for over 3 years, the hardest part about using it is, as stated, remembering to slam the "drop" pedal ALL the way down to lower it slowly, if you don't, it drops like a rock.
john
Yes I posted that coupon awhile back and a whole bunch of us spyderlovers got it for $59.
It works great!
All we found was a 20% off coupon code making it 79.99 and then 6.99 for ground shipping. Coupon code is : 99094294 (unknown expiration date)
We dont need immediately so will watch for an even better sale
2013 RS-S Neutron Green/Black, Shark RSR2 helmet, Shark Evoline 3 helmet, Sena SMH20, Corbin Seat, Wheelchair Rack, Trunk Liner, STL Handlebars, Web Boards Driver Floorboards, backrest, BRP Givi Saddlebags, ISCI Handbrake
My coupon is for limit 5 in the store or online and on the phone it expires 11/24/12. The code # 82949091
69.99 Lot no. 2792
Got it out of Motorcyclist magazine page 119.
Has anyone that has Seal Floorboards used this lift? I am wondering since Seal Floorboards stick out as much as they do (a good thing) if the lift can get close enough to work properly.
Yep, it worked on my RTS when I installed the Seals this morning. I first jacked up the RTS to put her on jack stands, but I was a bit nervous when I took it off the stands to let the RTS down. Just don't push the jack in too far. It should be in just far enough so the front end of the jack pads goes fully under the frame of the Spyder otherwise it would be too close for my comfort.
happy old fart
It won't get close enough with Seals on an RT much to my disappointment.
Stillriding, it worked fine on my RTS this morning both before and after installing the seals RT SM5 DLX version.
