Originally Posted by JJW SpyderRider
Right now I'm only seeing 2 bars at speed while around 40 outside and between 1-2 when in the 30's . Stock engine and still gets to 5 bars at stop lights.
Sounds like your thermostat may be stuck open.
1-2 bars
Yea I thought that too. My first winter with the Spyder and not sure what was normal. I will have it looked at when they do the DPS update.
Nancy's RS runs 2-3 bars at speed in cold weather. You can watch it go up and down there, so I am certain her thermostat opens right about at the 2-3 junction...probably a little way into 3. Yours is worth checking. If it does not run poorly, I would not worry much about it, though...unless your state has emissions testing.
Less than 60 degrees outside and mine stays at 2 bars until I slow down to less than 50 or so. It may climb some then, but goes back down quickly once it gets clean air. Probably nothing to worry about.
I've just recently dropped to two bars intermittently when in the low 50's. One other thing I have noticed with the MAD is that I could be running at 3 bars and then go in the opposite direction causing the number of bars to increase. So, the MAD and the cooling set up are wind directional sensitive; either more or less air is being pushed through based on the direction you are riding. I know this isn't earth shattering; but, just thought I'd throw it out there.
Originally Posted by BLACK WIDOW
I actually had the KewlMetal intake (sold it on this web site) didn't like the noise and the Green filter seemed to provide the same or better performance. The Kewl Metal set-up eliminates the "Velosity stacks" built into the air box, thus making performance gains suspect.
I know you've said this before and their was some previous discussion concerning this issue, but what proof does anyone have? Mine is that I differently am pulling a lot more air in with it, I know this because when I added the intake with just having the Hindle I had to add the JB and the 02mod because I was running way to lean. I would really like some opinions on this subject.
ISCI had their Spyder at Daytona Speedway for Biketoberfest, and had a prototype fan shroud on it behind the radiator. Jeff was ryding it, and was only wearing Crocs the entire time. They had a temp gauge hooked up at the point where the coolant would be the hottest for testing, and it never went above 210 degrees. It actually forces the air out underneath the Spyder instead of attempting to blow it out the side hole, and appears to be very effective. This might be a good thing to keep your eyes open for.
Also very happy with o 2 mod.No more backfiring on decel and my idle is less erratic.
Air
Originally Posted by Campverdefela
[/COLOR] I know you've said this before and their was some previous discussion concerning this issue, but what proof does anyone have? Mine is that I differently am pulling a lot more air in with it, I know this because when I added the intake with just having the Hindle I had to add the JB and the 02mod because I was running way to lean. I would really like some opinions on this subject.
The "Green" filter will flow about 2x the air the factory filter will deliver, while providing excellent particle filtration. At max RPM's the Green filter should deliver all the air the engine can ingest. Eliminating or altering the velosity stack tuning ( in the factory box) is a negative performance gain and a positive noise gain. I think the "Magic Man" has some flow data on the Green filter that may be of of interest to you. I think some real performance gains could be realized with the introduction of cooler air at the intake of the factory box with a high flow air filter. IMHO
I don't dispute that the Green filters performance which can be backed up with proof but where's the proof that the Kewlmetal's intake has a negative effect on performance. Speculation is one thing.
tuning
That is something you will just have to decide for yourself. There is good information available (research) on fuel/air tuning, velosity stacks & effects there of. The KewlMetal filter will no doubt increase flow over the stock set-up; However it does also tinker with the fuel/air tuning of the engine. The velosity stacks were designed into the air box for a reason.
Yes but that's the idea, the stacks work in conjunction with the big box, while the aftermarket intakes out their have no box, different animal. Again I'm asking anyone out their for proof....
Proof??
[/COLOR]
Maybe you will just have to prove it yourself (one way or the other) through your own research.
Your the one that first make the negative comment about the Kelwmetal setup without proof, if your going to say it then back it up.
BlackWidow, are you referring to the rubber air tubes on the stock airbox? The tubes are acoustically tuned to lower throttle body and air intake noise. They also benefit from drawing cooler air near the front of the air dam.
The KewlMetal intake will flow more air but, with the plastic body panels in place, will draw more heat radiating from the engine. Clearly, not an ideal design.
And, personally, I'm not a fan of oiled filters (K&N, "Green" Filter, etc.) anyway. I've seen the filtration test results and the synthetic media filters are significantly more efficient and cheaper to maintain over the life of the engine.
I went with the synthetic aFe filter (manufactures the Evoluzione filter) and cut off the interior portion of the rubber tubes.
Yeah, but I enjoy all that space around the engine, easy to change plugs, check hoses, etc, you get the idea. Oh, BTW don't tell my Spyder that its runnig an inferior setup as she runs like she's being chased...Oh...maybe she is....
Proof
The proof is in the theory of fuel/air tuning and velosity stacks--You can read the same info that I have. I did some research on the subject since it was of interest to me. To my knowledge the KewlMetal system has never been ran on a Dino so there is no proof for that particular piece of equipment; One can only speculate on performance based on the theory of fuel/air tuning. I must say that if you like your current set-up and don't mind the noise then that is the set-up for you. My experience was much different, the noise was much greater and the performance wasn't . I actually sold it at a substantial loss. The negative statements you are referring to are based on my personal experience, just as yours are on all the performance gains that you say you realize. I do believe that the EVO system has the velosity stacks built into their system and would theorize that the performance would be better.
Tubes
No, I am actually referring to the Hard plastic velosity stacks inside the air box just above, and bolted to, the engine intake. I removed the rubber tubes you are refering to in order to allow unrestricted air flow into the box. The addition of a cold air intake into the stock box with a high flow filter could be a substantial performance gain. IMHO
All I know is that if I put my airbox back on in place of the race intake I have to reduce the amount of fuel or it runs rich. That is proof enough for me that it increases airflow and leans out the engine.
Given the same pressure differential velocity stacks can help make the air flow smoother but is a relative small gain
The difference between a kewlmetal or race air and stock box is all about pressure drop across filter/box
If u didn't get improvements it because you didn't add enough fuel
Two Brothers Juice Box Premuim and 02 Modifier
I have a Leo Vince pipe and the Two Brothers Juice Box Premium. I still get popping on deceleration. Bike acts like it is too lean at idle (ruff Idle and hesitation when rolling on the throttle from idle) Has anyone used a 02 Modifier and Two Brothers Juice Box Premium together? What were your results? Any help would be appreciated.
I have been running the 02 modifier for a year and a half and I am going to take it out and put back the stock one. I do like the low end torque it gives but have not been happy with the fuel economy I have been getting and after my last ride from NJ to Lake Placid NY and got an average of 20mpg it's coming off, some have also suggested it might also make the bike run hotter .
How is the installation? is it very easy to install, like a 5min job? I am tempted, but have not seen any instructions on how to install the O2...
Tks!
